Reusable Solution Libraries
After selecting an SCL solution, a dialog will appear prompting you to choose a save path format.
However, if the path of the selected SCL solution is located within the Solution folder or the Scene Composer folder, it will automatically be saved as a relative path. In this case, the dialog explained in the below will not be shown.
In this dialog, you can select either a relative path or an absolute path. If you choose to use a relative path, you can further specify the reference base from the following two options:
Relative to Scene Composer
Relative to solution
If the selected SCL solution exists on the same drive, the relative path option will be available, as shown in the figure above.
If the selected SCL solution exists on the same drive, the relative path option will be available as shown in the figure above.
However, if the selected SCL solution is located on a different drive, it cannot be converted to a relative path. In such cases, the dialog will display only the "Absolute Path" option.
- Inherited (the element, if it is a leaf, will inherit the property of the parent)
- Public (the element will be available as a reusable/shareable resource)
- Private (the element will not be available as a reusable/shareable resource)
