Solution Information
This feature allows you to set an easily recognizable name, description, and thumbnail image for each solution. This makes it possible to instantly grasp the content of a solution on the Scene Composer Startup Panel, preventing mix-ups and editing mistakes. Even when managing multiple projects in parallel, you can immediately identify the purpose of each solution, making it a powerful management tool that helps streamline your daily editing work and project progress.
Title
Sets the name of the solution.
You can assign any name that differs from the file name, allowing you to identify the solution with a clear and meaningful name for project management. The name is displayed in the tooltip on the Scene Composer Startup Panel.
Allows you to set a description for the solution.
By noting the purpose of the solution, testing objectives, or key points in its editing history, this description serves as a useful reference when managing multiple solutions. The description is displayed in the tooltip on the Scene Composer Startup Panel.
Selected Image
Allows you to set a reference image that makes it easier to visually identify the solution. This image is displayed as a thumbnail on the Scene Composer Startup Panel.
  • Browse: Select a static image file to use as the thumbnail. This disables the default behavior for the solution’s thumbnail.
  • Revert: Delete the currently set image (whether a static image or the most recent screenshot) and enable the default behavior.
Default behavior: When you perform [Save] for the solution, a screenshot of the current state is captured automatically and used as the thumbnail. Therefore, after performing Reset, be sure to perform [Save] for the solution.
Image Preview When an image is selected using “Selected Image,” a preview of the image will be displayed here.
