Using Animation Callback Functions
Animation Event Listener
If an application shall be notified about events of the triggered animation, a listener needs to be implemented. The class Candera::Animation::AnimationPlayerListener allows to listen to a versatile set of animation events like:
  • OnStartAntimation,
  • OnResumeAnimation,
  • OnPauseAnimation,
  • OnDirectionChange,
  • OnStopAnimation,
  • OnFinishAnimation,
  • OnPastEnd.
Implement AnimationPlayerListener Functions
In order to register an AnimationPlayerListener to an AnimationPlayer simply derive from Candera::Animation::AnimationPlayerListener and override pure virtual functions with custom code.
In the example below the 3D application derives from AnimationPlayerListener and overrides the listener's functions.
class AnimationPlayerWidget : public CgiWidget3D, public Candera::Animation::AnimationPlayerListener
        virtual void OnPastEnd(Candera::Animation::AnimationPlayerBase* animationPlayer, Candera::Int32 completedIterationsCount);
        virtual void OnStartAnimation(Candera::Animation::AnimationPlayerBase* animationPlayer);
        virtual void OnStopAnimation(Candera::Animation::AnimationPlayerBase* animationPlayer);
        virtual void OnFinishAnimation(Candera::Animation::AnimationPlayerBase* animationPlayer);
        virtual void OnResumeAnimation(Candera::Animation::AnimationPlayerBase* animationPlayer);
        virtual void OnPauseAnimation(Candera::Animation::AnimationPlayerBase* animationPlayer);
Use Candera::Animation::AnimationPlayerBase::AddAnimationPlayerListener and Candera::Animation::AnimationPlayerBase::RemoveAnimationPlayerListener for registering or removing a listener.
        static_cast<void>(m_animPlayer->AddAnimationPlayerListener(this));
        static_cast<void>(m_animPlayer->RemoveAnimationPlayerListener(this));
Now the application is notified about all animation listener events it has implemented. For example when implementing the Candera::Animation::AnimationPlayerListener::OnStartAnimation, the application is notified about all started animations.
void AnimationPlayerWidget::OnStartAnimation(Animation::AnimationPlayerBase* /* animationPlayer */)
    // do something when an animation has started
