Diagnostic
FPS Display
The FPS Display Control provides a Text Node that displays the currently rendered frames per second, which allows to benchmark running applications.
Properties
Property Name
Type
Render Target RenderTargetType The render target which FPS should be monitored.
Text Style
Candera::TextRendering::Style The Style that will be set to the Text Node.
Text Color
Candera::Color The color to set.
Text
String Text that TextBehavior will change the Node to. Supports formatting for one variable that corresponds to the value TextProcessValueBehavior2D receives.
Blend Type
BlendType::Enum The blend type that will be set.
FrameCounterDisplay
The Frame Counter Display Control provides a Text Node that displays how many frames were already rendered.
Properties
Property Name
Type
Render Target
Text Style
Text Color
Text
Blend Type BlendType::Enum The blend type that will be set.
FrameTimeDisplay
The Frame Time Display Control provides a Text Node that displays the time it takes between frames to be rendered, which allows to benchmark running applications.
Properties
Property Name
Type
Text Style
Text Color
Text
Blend Type
FPSDisplay3D
The FPS Display 3D Control provides a CanvasText that displays the currently rendered frames per second, which allows to benchmark running applications. This control is available for 3D scenes.
Properties
Property Name
Type
Text Style
Text Color
Text
Blend Type
FrameCounterDisplay3D
The Frame Counter Display 3D Control provides a CanvasText that displays how many frames were already rendered. This control is available for 3D scenes.
Properties
Property Name
Type
Render Target
Text Style
Text Color
Text
FrameTimeDisplay3D
The Frame Time Display 3D Control provides a CanvasText that displays the time it takes between frames to be rendered, which allows to benchmark running applications. This control is available for 3D scenes.
Properties
Property Name
Type
Text Style
Text Color
Text
String
Blend Type
