Transition panel
This page describes the panels you can use when configuring and executing transitions.
Transition Rules Editor
The Transition Rule Editor panel can be displayed by checking [ View > Transitions > Transition Rules Editor ] on the menu bar.
| (1) |
Add new transition rule: Add a new transition rule. |
| (2) |
Delete transition rule: Deletes the selected transition rule. |
| (3) |
Search: If many transition rules are set, you can enter a search term to narrow down the number of results displayed. |
| (4) |
Clear Search: Delete the search term. |
| (5) |
Source: Set the source of the transition. |
| (6) |
Transition Type: Set the transition type. |
| (7) |
Destination: Set the destination of the transition. |
| (8) |
Activation/Deactivation: Set the activation delay/deactivation delay. |
| (9) |
Variant: Sets the transition rule variant. |
Transition Execution
The Transition Execution panel can be displayed by checking [ View > Transitions > Transition Execution ] on the menu bar.
| (1) |
Add an example of a new transition execution: Add a new transition execution procedure. |
| (2) |
Delete transition execution example: Delete the selected transition execution procedure. |
| (3) |
Add an example of how to use a scene: Add a scene use case to the transition execution procedure. |
| (4) |
Delete Scene Example: Delete the selected scene use case. |
| (5) |
Execute Transitions: Run transition execution procedure. |
| (6) |
Scene: Set the scene to be transitioned. |
| (7) |
Action: Set the action to be taken by the transition. (Activate: Transition to the set scene, Deactivate: Transition from the set scene to another scene) |
| (8) |
For more information on how to configure transitions, please refer to Concepts and Use Cases and Using Transitions.
