Pivot Hint
Pivot Hint is a property of a Bitmap which allows to set the coordinates of a point that will be used as default Pivot Point for the RenderNode that uses the Bitmap.
The example hereafter presents the situation of replacing the Hour Needle Image on an AnalogClock control with a bitmap having or not having set the Pivot Hint.
