GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. The right side displays a List of devices. When a device gets selected, an associated Sub-List Control with two TextButtons will be shown.
Preparing the Options scene
A scene will be created and the camera will be configured in the Render Targets panel.
  1. Create a new scene via the menu bar "Scene" - "New 2D Scene" or press < Ctrl+2 > on your keyboard
  2. In the first row select "/Scenes" from the drop-down menu. Enter "SceneOptions" as name and press [OK]. We use the prefix "Scene" to have all scenes listed next to each other in the Solution Explorer panel.
  4. In the Render Targets panel select the SceneOptions\Camera. In the Properties panel's [Camera] section change the sequence number to 2.
Importing Images
  1. In the menu bar select Import > Import Resources...
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 16 files and press [Open]
      Import Resources
      Path
  3. In the "Import Images" dialog select folder "/Resources", make sure to create a new folder "Options" for the imported images and click [OK].
Configuring the Background
This scene is composed of two parts: Connection and Devices. For each of these parts a 2D Group node will be created. To position the background image a BitmapNode will be configured with one of the images imported in the previous section.
  1. From the Toolbox panel's [Node 2D] section drag a 2D Group node into the Scene Tree directly onto the node "SceneOptions".
  2. From the Toolbox panel's [Node 2D] section drag a BitmapNodes onto the 2D Group node.
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
  5. In the Scene Tree panel select the BitmapNodes called "Background" one after the other and perform the following instructions on both background nodes: In Scene Tree panel's right side select the "BitmapBrushBlend" effect. In the Properties panel's [Effect] section click on the magnifying glass icon next to the Image property.
  6. In the "Choose Item" dialog select the image as in the table below and click [OK].
      Node Effect Property
      Path
      Connection > Background BitmapBrush Blend Image
  7. In the Scene Tree panel select the "Connection" group. In the Properties panel's [Transformations] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
      Target Name
      Position X
      Position Y
      Connection
      78.00
      58.00
      Devices
      551.00
      58.00
The left side of the scene offers the possibility to choose the connection type. The Scene Composer's built-in Dial control will be customized with new images that fit to the scene's design. TextNodes will be added as labels.
  1. From the Toolbox panel's [Controls] section under Touchable drag a Dial control into the Scene Tree panel directly onto the "Connection" group.
  2. In the Scene Tree panel select the Dial control. In the Properties panel's [Transformation] section adjust its position according to the table below.
      Target Name
      Position X
      Position Y
      Dial
      72.00
      163.00
The following steps show how to configure the Dial control with new images.
  1. In the Properties panel's [Control] section click on the magnifying glass icon next to property "Knob Image".
  2. In the "Choose Item" dialog select the image as in the table below and click [OK].
      Property
      Path
      Knob Image
  3. In the Properties panel's [Control] section click on the the "BackgroundImages" section.
  4. In the Properties panel's [BackgroundImages] section click on the magnifying glass next to "BackgroundImages 0".
  5. In the "Choose Item" dialog select the image as in the table below and click [OK].
    • In the Properties panel the first one of the BackgroundImages has been configured.
      Property
      Path
      BackgroundImages 0
      /Resources/Options/NewDial_background_leftBmp
  6. Repeat steps 4 and 5 to configure the remaining BackgroundImages. After this step the BackgroundImages are configured according to the table below.
      StateImages
      Image Path
      BackgroundImages 1
      BackgroundImages 2
  7. In the Solution Explorer panel select the new Knob Image "/Resources/Options/NewDial_arrow_middleBmp". In the Properties panel's [Bitmap] section enable "Pivot Hint" by checking the respective checkbox.
      Target Name
      Pivot Hint Y
      88,00
  9. In the Solution Explorer select the three images that were configured as BackgroundImages. In the Properties panel proceed similar to steps 7 and 8, enabling and configuring the Pivot Hint of these three images according to the table below.
      Target Name
      Pivot Hint Y
      130,50
      130,50
      130,50 130,50
      130,50 130,50
TextNodes will be configured with an attractive font and positioned as labels for choosing the connection type.
  1. From the Toolbox panel's [Nodes 2D] drag and drop a TextNode into the Scene Tree panel directly onto the "Connection" group node.
  2. In the Scene Tree panel select the new TextNode. In the Properties panel's [2D Text Node] section click on the magnifying glass icon next to property "Style".
  3. In the "Text Style Palette" dialog select "OpenSans25" and click [OK].
  4. In the Scene Tree panel right click onto the TextNode and select "Clone..." from the context menu.
  5. In the "Clone Item" dialog change to the "Multiple Clone" tab. Configure "Number of Copies" to "3" and click [OK].
      Text Position X Position Y
      TextNode_Cable Cable 20 200
      TextNode_Other Other 315 200
The right side of the scene displays a list of devices. Scene Composer's built-in List control will be expanded to facilitate customization later on. Based on the existing List control a new reusable MyList control template will be created.
  1. In the Scene Tree panel copy the TextNode_Connection from the Connection Group2D either via the context menu "Copy"  or via the keyboard shortcut <Ctrl + C>. Paste the TextNode into the Devices Group2D either via the context menu "Paste" or via the keyboard shortcut <Ctrl + V>.
    • In the Scene Tree panel you can see that TextNode_Connection has been copied to the Devices group.
    • In the Scene Editor another Textnode with "Connection" is visible.
  2. In the Scene Tree panel select the new TextNode_Connection from the Devices group and rename it to TextNode_Devices either via the context menu "rename" or via the keyboard shortcut <F2>.
    • In the Scene Tree panel you can see a TextNode called TextNode_Devices inside of the Devices Group2D.
  3. In the Scene Tree panel select TextNode_Devices. In the Properties panel's [2D Text Node] section change the TextNode's Text property and in the [Transformation] section adapt its Position according to the table below.
    • Text and position of the TextNode are configured.
    • In the Scene Editor you can see that the devices part has got a headline.
      TextNode_Devices Devices 145 61
  4. From the Toolbox panel's [Control] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
  5. In the Scene Tree panel right-click on the newly created List node and choose [Expand Control Node] from the context menu.
  6. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [Expand Control Node] from the context menu.
  7. In the Scene Tree panel right-click on the List node and choose [Save as Control...] from the context menu.
  8. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [OK].
    • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [Controls] section as last item of the list.
Configure MyList Control
Scene Composer's List internally holds a property for the scrollbar's visibility, which is not shown in the Properties panel by default. The following steps show how to access a list of hidden properties. For this sample solution we will make the scrollbar's visibility property publicly editable in the Properties panel.
  1. In the Solution Explorer right-click on the newly created control "MyList" and choose [Control Properties...] from the context menu.
  2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [OK].
  5. In the "Delete Item" dialog press [OK].
    • The List node is deleted.
  6. From the Toolbox panel's [Control] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
  7. In the Scene Tree panel select "MyList". In the Properties panel's [Control] section set the "Scrollbar Visibility" to "Visible".
Customize MyList's Scrollbar
Scene Composer's default scrollbar has a blue base color. For our orange based design the scrollbar will be customized in the steps below.
      Thumb Images
      Image Path
      VerticalPrevItem Images
      Image Path
      VerticalNextItem Images
      Image Path
Configure MyList's Main Item
Our MyList control will be composed of MainItems. Whenever a certain MainItem gets selected, the appropriate Sub-List will be displayed. The following steps explain how to build up a MainItem.
  2. From the Toolbox panel's [2D Nodes] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
  3. From the Toolbox panel's [2D Nodes] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
  4. In the Scene Tree panel select the nodes created in the previous steps and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
      Initial Name
      New Name
      OverlayLayout MainItem
      TextNode EntryName
      RenderNode FocusImage
  5. In the Scene Tree panel select the List (Group2D). In the Properties panel's  [Transformation] section configure the position and size according to the following table.
      Target Item
      Transformation
      Layout
      List (Group2D)
      58
      134
      300
      300
In a list it is useful to highlight the selected item. This will be done using a FocusImage drawing a border around the focused MainItem.
  3. In the "Choose Item" dialog select the image as in the table below and click [OK].
      Target Item
  4. In the Properties panel change the Color property by entering new values for "Red", "Green" and "Blue" according to the table below.
      Target Item
      Color
      Red
      Green
      Blue
      0.62
      0.00
  5. In the Scene Tree panel select the FocusImage node. In the Properties panel's [Layout] section set the StretchBehavior to "Fill" according to the table below.
    • In the Scene Editor the FocusImage RenderNode will appear highlighted with an orange outline.
      Target Item
      Layout > StretchBehavior
      Fill
Create MyList's Sub-List
A Sub-List will be used to display 2 TextButtons to "Connect" or "Unpair" the associated device. The TextButtons will be positioned by a StackLayout. New images for normal, pressed and focused image will be defined.
  1. From the Toolbox panel's [Controls] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
  2. From the Toolbox panel's [Node 2D] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
  3. From the Toolbox panel's [Controls] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
  4. In the Scene Tree panel select the StackLayout. In the Properties panel's [Transformation] and [Layout] section configure the properties as in the table below.
      Target Item
      Transformations
      Layout
      Scale X
      Scale Y
      Margin Left
      TextButton
      0,75
      0,75
      12
  5. In the Properties panel's [Control] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
  6. In the "Choose Item" dialog select the image according to the table below and click [OK].
  7. Repeat steps 5 and 6 for the TextButton's "Pressed Image" and "Focused Image".
      Target Item
      Image Path
      Normal Image
      Pressed Image
      Focused Image
  10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [Control] section according to the table below.
    • The texts of the TextButtons have been changed.
      Target Item
      New Name
      Control - Text
Configure Behaviors for the Focus Handling of MyList's MainItem
Whenever MyList's MainItem gets focused, an orange border shall be displayed. Focus and FocusLeave behaviors are used to enable or disable the rendering of the FocusImage. The behaviors are configured using Fusion.
A detailed explanation about Fusion, how to operate Fusion (how to add Fusion Nodes) and a configuration example can be found in the documentation about Fusion.
  1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [Item] section uncheck "Enable Rendering".
  2. In the Scene Tree panel select the MainItem GroupNode. Then press the [Fusion...] button on the right side of the Scene Tree.
    • Fusion panel is opened displaying the Fusion diagram with the MainItem Fusion Node.
    • The MainItem Fusion node has a Behaviors connector on its right side.
  3. Add Fusion Nodes to the MainMenu Fusion Node using its Behaviors connector according to the table below.
    • Three new Fusion node will be added to the Fusion diagram: Handle Control State, Focus, FocusLeave.
    • Focus Fusion Node and FocusLeave Fusion Node can be configured with [Action] connectors.
      Connect to
      Connector
      Add Fusion Nodes
      Behaviors
      Behaviors
      Focus
      Behaviors
      FocusLeave
  4. Add Fusion Nodes to the Focus Fusion Node and the FocusLeave Fusion Node using their Actions connectors according to the table below.
    • An EnableRendering Fusion Node will be connected to the Focus Fusion Node.
    • An EnableRendering Fusion Node will be connected to the FocusLeave Fusion Node.
      Connect to
      Connector
      Add Fusion Nodes
      Focus Fusion Node
      Actions EnableRendering
  5. Configure the properties "Visible" and "Target Node" for both EnableRendering Fusion Nodes nodes according to the table below.
    • Whenever the MainItem looses the focus, the FocusImage will get invisible.
      Behavior
      Visible
      Target Node
      Focus - EnableRendering
      FocusLeave - EnableRendering
  1. In the Scene Tree panel select item MyList > List > ListContentGroup > MainItem. Then press the [Fusion...] button on the right side of the Scene Tree.
    • Fusion is opened displaying the Fusion diagram with the MainItem Fusion Node.
    • The MainItem Fusion Node has a Behaviors connector on its right side.
  2. Add Fusion Nodes to the MainItem Fusion Node using its Behaviors connector according to the table below.
    • A new Fusion node will be added to the Fusion diagram: Event Handler Fusion Node.
    • The Event Handler Fusion node has 2 connectors on its right: a Condition connector and an Action connector.
      Connect to Fusion Node
      Connector
      Add Fusion Nodes
      MainItem
      Behaviors
      Event Handler
  3. Add Fusion Nodes to the Event Handler Fusion Node according to the table below.
    • A new Fusion node will be added to the Fusion diagram: Check Logic Condition Fusion Node.
      With the Check Logic Condition you can combine 2 conditions with a configurable logic operation (And, Or, Xor).
      Connector
      Add Fusion Nodes
      Event Handler
      Condition
  4. Add two Fusion Nodes to the Check Logic Condition Fusion Node using its Conditions connector according to the table below.
    • 2 new Fusion Nodes will be added to the Fusion diagram: Check Key Input Fusion Node and Check Click Fusion Node.
      Connector
      Add Fusion Nodes
      Condition
      Check Key Input
      Condition
      Check Click
  5. Configure the Condition Fusion Nodes according to the table below.
    • Check Click and Check Key Input condition are logically combined through Check Logic condition.
    • The Check Logic condition will evaluate to TRUE if either the Check Click condition or the Check Key Input condition is TRUE.
      Condition
      Property
      Value
      Operation
      Or
      Check Click  - -
  6. Add a Fusion Node the Event Handler Fusion Node using its Action connector according to the table below.
    • A new Fusion Node will be added to the Fusion diagram: Send Value as Event Fusion Node.
      Connector
      Add Fusion Nodes
      Event Handler
      Action
      Send Value As Event
  7. Configure the [Send Value as Event] Fusion node according to the table below.
    • Send Value As Event is configured according to the table.
    • On every click or enter key press a boolean value will be sent to the Sub-List control.
      To configure the TargetNode click on the magnifying glass icon to open the [Choose Item] dialog. Navigate to the desired object and press [OK].
      Behavior
      Property
      Value
      Value Bool - TRUE
      Change Value
      Relative
The visibility of the Sub-List shall be toggled by clicking the MainItem. Let's configure the necessary behaviors to the Sub-List.
  1. In the Scene Tree panel select item MyList > List > ListContentGroup > Sub-List node. Then click the [Fusion...] button on the right side of the Scene Tree.
    • Fusion is opened displaying the Fusion diagram with the Sub-List's Fusion Node.
    • The Fusion node has a Behaviors connector on its right side.
  2. Add a Fusion Node the Sub-List Fusion Node using its Behaviors connector according to the table below.
    • A new Fusion Node will be added to the Fusion diagram: Value Fusion Node.
      Connector
      Add Fusion Nodes
      Sub-List
      Behaviors
      Value
  3. Configure the Value Fusion Node according to the table below.
    • The Value behavior's type has been changed to Bool.
      Behavior
      Property
      Value
      Value
      Variant Bool - FALSE
  4. Add a Fusion Node the Value Fusion Node using its Receivers connector according to the table below.
    • A new Fusion Node will be added to the Fusion diagram: Action On Value Fusion Node.
      Connector
      Add Fusion Nodes
      Value
      Receivers
      Action On Value
  5. Add two Fusion Node the Action On Value Fusion Node according to the table below.
    • 2 new Fusion Nodes will be added to the Fusion diagram: Check Processed Value Fusion Node and Set Control State Fusion Node.
      Connector
      Add Fusion Nodes
      Action On Value
      Condition
      Actions
      Set Control State
  6. Configure the newly added Fusion Nodes according to the table below.
    • The Action On Value Fusion Node is configured with an action that will be executed whenever a new value is received. In our case the Sub-List's Control State is set to enabled when the Bool value "TRUE" is received.
      Behavior
      Property
      Value
      ConditionOperator Equal
      ConditionValue Bool, TRUE
      Set Control State
      State Enabled
      ChangeTo TRUE
  7. Repeat steps 4 and 5 to configure another set of Fusion Nodes to the Value Fusion Node using its Receivers connector according to the table below.
    • 3 new Fusion Nodes will be added to the Fusion diagram: Action On Value_1 Fusion Node, Check Processed Value_1 Fusion Node and Set Control State_1 Fusion Node.
      Connector
      Add Fusion Nodes
      Value
      Receivers
      Action On Value_1
      Action On Value
      Condition
      Actions
      Set Control State_1
  8. Configure the newly added Fusion Nodes according to the table below.
    • The Action On Value_1 Fusion Node is configured with an action that will be executed whenever a new value is received. In our case the Sub-List's Control State is set to disabled (enabled = FALSE) when the Bool value "FALSE" is received.
      Behavior
      Property
      Value
      ConditionValue Bool, FALSE
      Set Control State_1
      State Enabled
      ChangeTo FALSE
Test MyList in the Player
Let's test if the configured behaviors of MyList control are functional.
  1. Save your solution either via the menu bar "File - Save Solution" or via the keyboard <Ctrl + S>.
    • The solution has been saved.
  2. In the Scene Composer's Toolbar click on "Play selected scenario...".
    • The resources will be generated and the Player will be started.
  3. In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
    • In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
  4. In the Player window click the first item of the Devices List, the text of which is "Text".
    • In the Player window's Devices List an orange border will be displayed indicating the selected MainItem.
    • Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
  5. In the Player window click the selected MainItem again.
    • The TextButtons of the Sub-List will disappear.
  6. In the Scene Composer's Toolbar click the "Close the Player" button.
    • The Player and CGI Panel window will be closed.
So far we have been working on our MyList control with only one single list entry. Now that this first list entry is fully configured, we can create more of them.
  1. In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [Copy] and [Paste] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
    • In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
  2. In the Scene Tree panel select the MainItems individually. Use Fusion to configure the appropriate TargetNode for the [Send Value As Event] Fusion nodes (see table below).
    • The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
      SendValueAsEvent of
      TargetNode
      MainItem /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List
      MainItem_1 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_1
      MainItem_2 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_2
      MainItem_3
      /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_3
      MainItem_4
      /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_4
  3. In the Scene Tree panel select MainItem's EntryName. In the Properties panel's [2D Render Node] section change the property "Text" according to the table below.
    • In the Scene Editor you can see the changed texts.
      TextNode2D
      Text
      MainItem > EntryName
      Phone (Private)
      MainItem_1 > EntryName Phone (Work)
      MainItem_2 > EntryName New Device
      MainItem_3 > EntryName
      New Device
      MainItem_4 > EntryName
      New Device
Check the Options Scene
The Options scene is now finished.
  1. To check the result of configuring the first scene, open the display view. This view represents the final rendered result and can be opened via the menu bar: View - Display - Display-0.
  2. In the Scene Composer's Toolbar make sure that the item "Generate and Play" is selected in the drop-down menu and click the [>] button to the left.
  3. In the CGI Panel tick the checkbox next to "Scenes#SceneOptions" and uncheck "Scenes#SceneHome".
    • SceneOptions will become visible in the Player.
  4. You can now play around with the configured Options Controls in the scene and watch the results.
    • Grab the Connection Dial Control and switch between Cable, Bluetooth and Other.
    • Click into the Devices List to open the Sub-List.
    • Click on the Sub-List's "Connect" and "Unpair" TextButtons and watch the configuredhover and click effects.
    • Click on several devices in the Devices List to make multiple Sub-Lists visible. Now you can test the scrollbar.
