Rendering Only Updated Content
This chapter briefly describes how to achieve performance optimization by rendering only updated content.
Introduction
Invalidation Introduction
Basic principles for composing graphical content:
- Place content which is never changed in an own scene and render it to an own layer.
- Partition content which is frequently changed by widgets or animations. Use several cameras for this purpose.
- If rarely modified graphical content is part of a dynamic scenery then think about using Texture Render Targets.
How is it done?
In the render loop of the application all Widgets are updated by calling Candera::WidgetBase::Update(). The basic render loop looks like this:
// 3D Render Loop
// handle input events
// update animations by calling AnimationDispatcher::DispatchTime()
if (m_animationDispatcher3D != 0) {
m_animationDispatcher3D->SetWorldTimeMs(nowMs);
m_animationDispatcher3D->DispatchTime();
// update all widgets
CgiApp::GetInstance().Update();
Renderer::RenderAllCameras();
// end 3D Render Loop
The widgets must now implement a mechanism to tell the application whether associated graphical content needs to be rendered. The following pages explain two ways to achieve this:
Use SetRenderingEnabled()
Use Candera::Camera::SetRenderingEnabled() / Candera::Camera2D::SetRenderingEnabled()
The example below shows how in CGIApplication all 3D cameras are turned off in first step of render loop.
void CgiApp3dGc::Update() {
Base::Update();
// Turn off all cameras
UInt32 cameraCount = Renderer::GetCameraCount();
for (UInt32 i = 0; i < cameraCount; i++)
Camera* cam = Renderer::GetCamera(i);
cam->SetRenderingEnabled(false);
// Update widgets in all visible scenes
WidgetBase* widget = 0;
Vector<SceneContext*>::ConstIterator it = m_sceneContexts.ConstBegin();
for (; it != m_sceneContexts.ConstEnd(); it++) {
if ((*it) != 0 && (*it)->GetScene() != 0 && (*it)->GetScene()->IsRenderingEnabled()) {
widget = (*it)->GetFirstWidget();
while (widget != 0) {
widget->Update();
widget = (*it)->GetNextWidget();
The Candera::Widget::Update() method needs to be implemented such that the recently turned off camera is turned on again whenever rendering is required. The Candera::Camera can be either set as a widget property or retrieved inside the scene by masking the widget and the associated camera with the same Candera::ScopeMask value.
void SampleBaseWidget3D::InvalidateCamera(bool value)
m_camera->SetRenderingEnabled(true);
void MyWidget::Update()
// update graphical content from cached property value(s)
Base::InvalidateCamera(true);
Pick Camera to Render
Explicitly Pick Camera to Render
Another method is to maintain a list of cameras by the application.
The render loop has to be changed
- to call Candera::Renderer::RenderCamera( Camera * camera )
- instead of Candera::Renderer::RenderAllCameras().
The application needs to take care on Render Buffer Swapping.
