Carefully Design your Lighting
Use Texture Compression
  • Per-vertex lighting is less expensive than per-fragment lighting.
  • Use as few lighting sources as possible (usually one light source is enough).
  • Use simplified, tailored lighting calculations.
  • Use light ranges to reduce the illumination area.
  • Pre-calculate your lighting effects by putting them into textures.
