Simplify Meshes
Reduce the number of vertices in a mesh in order to improve runtime and memory performance. If viewing angle to a mesh is rather steady, it is a preferred approach to maintain higher amount of vertices at the silhouette and mainly reduce vertices in front view.
A strongly simplified mesh does not necessarily lead to a diminished quality of visual appearance, if the level of detail matches the use case rendered (See also LOD Management).
