Tool bar
The toolbar is lined with icons for frequently used operations.
Each number in the image below corresponds to the below icon descriptions.
- Create a new solution
- Opne an existing solution
- Save solution...
- Open asset library generator dialog...
- Open safety asset library generator dialog...
- Run/Stop Player/Embedded Player, Update Embedded Player
- Select Player/Embedded Player setting (6. Select the player to launch when clicked.)
- Open automation scripts dialog...
- Undo
- Redo
- Add a new 2D scene
- Add a new 3D scene
- Add a new safety scene
- Select active scene
- Select perspective (Scene Design/Animation Design/User created perspective)
- Display/Hide Scene Editor
- Open Culture solution option dialog
- Select culture
- Create new animation
- Select animation
- Start animation
- Stop animation
- Animation fast forward speed
- Go back to one previous active item
- Go forward to one previous active item
- Edit current profile
- Add a new profile
- Delete current profile
- Select profile
- Start the execution of the script system
- Stop the execution of the script system
Icons through 19 to 32 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Animation: 19 to 24, Navigation: 25 and 26, Editor Profiles: 27 to 30, Scripting System: 31 and 32)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
