Shortcut Customization
Shortcut Options
SceneComposer provides many default shortcuts available on a list that can be accessed from the "Help" > "Hot keys" menu or by using the shortcut Ctrl + H.
Due to the huge number of available hot-keys (shortcuts), it could be difficult to find a specific hot-key. In order to solve this issue, a search option is available in the upper side of the Hot Key panel ("Help" > "Hot Keys").
It is possible to create a different profile (i.e. "Hot keys" list) on which the user can set his/her own shortcuts. In the "Environment" section from the "Preferences", the "Shortcuts" panel allows the creation of new shortcuts.
Practically speaking, the user may create as many new profiles as are necessary, every of them with its own shortcuts. Every of these new profiles can be saved, exported (to make a list of all new shortcuts available), or deleted. If the user creates a new shortcut based on a default shortcut from the "Default Profile", the new shortcut has to be associated with a new profile - created by using "Save As" option.
It is not possible to create a shortcut by using the "Shift" + key or "Alt" + key.
Create Shortcuts
To create new shortcuts there are three major steps:
Select one of the operations for which you would like to create a new shortcut in the left panel.
Here you have two different possibilities:
  • Remove the default shortcut by clicking "X" Button in column "Remove". Click in the "Press shortcut keys" field and press the new shortcut keys - a new shortcut is created.
  • Create a new shortcut (without removing the default shortcut) by clicking in the "Press shortcut keys" field and pressing the new shortcut keys. In that case the new shortcut will appear under the default one.
(1) Profile Applied Shortcut Profile
(2) Delete Delete the shortcut profile selected in (1)
(3) Save Save the shortcut profile selected in (1)
(4) Export… Export the shortcut profile selected in (1)
(5) ー Commands for which shortcuts can be assigned are listed.
(6) ー Displays the shortcut for the selected command selected in (5).
(7) Shortcut target
Set the Panel on which the shortcut is available.
(If set to "Global," the shortcut will be available in all Panels.)
(8) Press shortcut keys Click this field and press the shortcut key you want to add.
(9) Click Target If you want to add a mouse operation to a shortcut, perform the mouse operation in this field. The mouse operation performed will be displayed in (8).
(10) ー Add the shortcut displayed in (8) to the shortcut profile.
(11) Currently used for You will be notified if a shortcut added in (8) or (9) is being used by another command.
After all the new shortcuts are created the "Save As" button may be used to create a new profile with a desired name or just press the "OK" button to save all newly created shortcuts in the "Custom" profile.
It is possible to use many shortcuts associated with the same operation in a specific profile. In this way, you have the opportunity to use different shortcuts for the same operation.
If the new selected shortcut is used for another operation, you will be notified in the field entitled "Currently used for".
If you would like to get back the default shortcuts, the "Restore defaults" button provides the possibility to get them back.
