Export / Import
Plugins Available
Plugin Specific Options
Use the "Export" / "Import" buttons, placed above the Preferences window, to export or to import Preferences.
The export process will not imply Shortcuts and Favorites categories (available in Properties panel) which are distinctively exportable.
All the values and settings which belong to the application itself and to the configurable properties of the available plugins will be exported in a desired location. The exported .sccfg archive will contain different .XML files like CustomUIConfig, IAppConfig and ISVNConfig, etc. ...
For any configurable plugin, another specific .XML file will be added in this archive. This .sccfg archive that contains a given configuration could be imported on many other stations to provide the same desired Preferences settings. In this way, it will not be necessary to re-configure every workstation.
