XML Definition
Complex Types are defined in an XML Schema file which is located at “cgi_studio_connector/schema/ComplexType.xsd”. This file can be used to validate xml files and with some editors (e.g. Visual-Studio) and provide code-completion when writing the XML file.
ComplexTypeDefinition-Element
Root Element. List of Complex types.
Attributes:
None
Children:
| Argument | Occurrence | Description |
| ComplexType | 0 - * | Complex type |
ComplexType-Element
Defines a specific Complex type.
Attributes:
| native_type | Yes | Native data type (e.g. Candera::Vector3) |
| basic_type | Yes | Corresponding basic type. Valid values are: - Double - Single - Int8 - UInt8 - Int16 - UInt16 - Int32 - UInt32 - Int64 - UInt64 - Bool |
| basic_type_length | Yes | Length of basic type -1: Dynamic size >0: Fixed size |
| default_value | Yes | Default value of type |
Children:
None
Sample
Below a sample XML file is shown
<?xml version="1.0"?> <ComplexTypeDefinition xsi:noNamespaceSchemaLocation="../../tools/Core/Schema/ComplexType.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <ComplexType native_type="Candera::Vector2" basic_type="Single" basic_type_length="2" default_value="Candera::Vector2(0.0F, 0.0F)"/> <ComplexType native_type="Candera::Vector3" basic_type="Single" basic_type_length="3" default_value="Candera::Vector3(0.0F, 0.0F, 0.0F)"/> <ComplexType native_type="FeatStd::String" basic_type="UInt8" basic_type_length="-1" default_value="FeatStd::String("")"/> <ComplexType native_type="Custom::ByteArray" basic_type="UInt8" basic_type_length="-1" default_value=""/> </ComplexTypeDefinition> |
