Interface-Buffer
The main class of the generated interface is called “Interface-Buffer”. This class is responsible to handle the data, actions and events from both sides and provide them to the other side.
The Interface-Buffer class contains the following methods:
Init
Initializes the Interface-Buffer.
Argument Name Type Description
dataModel
DataModel The generated Data-Model. Used to initialize data-values of the Interface-Buffer
defaultActionQueueSize FeatStd::UInt32 Size of the Action-Queue in bytes. The action queue is used to store actions for later execution. By pre-initializing it with a proper size, costly runtime memory allocations can be avoided.
defaultEventQueueSize FeatStd::UInt32 Size of the Event-Queue in bytes. The event queue is used to store event for later handling. By pre-initializing it with a proper size, costly runtime memory allocations can be avoided.
SetDataValue
Sets data values of the Interface-Buffer. This method is intended to be called by the external system to send data to the CGI application.
interfaceId
InputInterfaceId::Enum Id of the interface to set the value.
data void* Pointer to the data to be set.
dataSize FeatStd::UInt32
Size of the data to be shared in bytes.
This value will be ignored for static sized data unless INTERFACE_DEBUG_SIZECHECK_ENABLED is defined.
Result: True if setting the data-value is successful. False otherwise.
GetDataValue
Gets data values of the Interface-Buffer. This method is intended to be called by the external system to send data to the CGI application.
interfaceId
OutputInterfaceId::Enum Id of the interface to get the value.
target void* Pointer where the value should be written.
maxTargetSize FeatStd::UInt32
Maximum size of in bytes that the ‘target’ can store.
dataSize FeatStd::UInt32*
Actual size of the data to be written.
Result: True if getting the data-value is successful. False otherwise. If the return value is false and the dataSize > maxTargetSize the cause for the failure was that not enough memory was available to store the output value.
TriggerAction
Triggers the specified action.
interfaceId
InputInterfaceId::Enum Id of the action to trigger.
data void* Pointer to data needed for the action.
Result: True if getting action was successfully triggered. False otherwise.
SwapActionQueue
Swaps the action queue.
ProcessEvents
Gets events of the Interface-Buffer. This method is intended to be called by the external system to send data to the CGI application.
eventHandler
Internal::EventHandler* Pointer to the Event-Handler object. This will be called for every event in the queue.
maxCount FeatStd::Int32 Maximum count of events to handle. Use ‘-1’ for unlimited amount.
The Event-Callback function must have the following arguments:
interfaceId
FeatStd::UInt32 Id of the event
data void* Pointer to the event data if available.
dataSize FeatStd::UInt32 Size of the event data if available.
ProcessInputDataValues
Synchronizes the Interface-Buffer input data values with the applications Data-Model. This method is intended to be called by the CGI application.
dataModel
DataModel* The generated Data-Model.
ProcessOutputDataValues
Synchronizes the Interface-Buffer output data values with the applications Data-Model. This method is intended to be called by the CGI application.
dataModel
ProcessActions
Executes all queued actions. This method is intended to be called by the CGI application.
actionContext
Action::ActionContext Action-Context used to execute the action functions and basic actions (e.g. Message-Actions)
sceneContext Scene::SceneContext Scene-Context used to execute the scene related actions (e.g. Scene-Interface or Scene-Table Interface)
maxCount FeatStd::Int32 Maximum count of actions to handle. Use ‘-1’ for unlimited amount.
TriggerGenericEvent
Raises a generic event. This method is intended to be called by the CGI application.
interfaceId
OutputInterfaceId::Enum Id of the event to raise.
data void* Pointer to the data of the event if available.
Result: True if an event was raised (considering additional conditions). False otherwise.
TriggerMessageEvent
Raises a message event. This method is intended to be called by the CGI application.
message
Courier::Message* Message to check if an event is to be raised.
TriggerFunctionCallEvents
Raises Function-Call events. This method is intended to be called by the CGI application.
actionContext
Action::ActionContext* Action-Context used to call related Event-Functions.
SwapEventQueue
Swaps the event queue.
