Overview of the graphical user interface
This section contains:
The MemoryPool-Analyzer module extends the tab region of the Analyzer ribbon area.
The tab is split in three different groups:
  • View: Filter and selection of a subset of traced data
    • Memory Pool Explorer:
      Shows the hierarchical memory structure. Content of review will be changed based on this selection.
      See also:
    • Global Time Slider:
      This time slider provides access to memory snapshots. Most features are bound to this snapshot.
      See also:
      Global Time Slider
    • Memory Pool Properties:
      Provides general Properties of selected nodes (Memory Pool Explorer) at the specified memory snapshot.
      See also:
      Memory Properties
  • Reviews: Access to statistics and analysis views
  • MemoryPools: Contains general content to improve the usability
    • Memory Settings:
      Provides several settings to configure the module.
      See also:
      Settings
    • File Editor:
      The Analyzer supports opening filepaths and present these files within the file editor.
      See also:
      File Editor
    • Refresh:
      Reloads dataset into views. If some errors in views occurred or dataset is not loaded properly, this button will reload these data and try to fix erroneous views.
