Control Behaviors Flags
  • CONTROLS_BREADCRUMB_BEHAVIORS_ENABLED - Build with BreadCrumb Behaviors
    (BreadcrumbActionBehavior, BreadcrumbBehavior)
  • CONTROLS_DEMO_BEHAVIORS_ENABLED - Build with Behaviors intended for demonstration purpose
    (ValueGeneratorBehavior)
  • CONTROLS_EDITTEXT_BEHAVIORS_ENABLED - Build with Edit Text Behaviors
    (CaretBehavior, EditTextBehavior, EnterExitConditionBehavior)
  • CONTROLS_EXTERNALRESOURCE_BEHAVIORS_ENABLED - Build with External Resource Behaviors
    (ExternalBitmapProviderBehavior, ExternalResourceChangeConditionBehavior, SetExternalBitmapActionBehavior)
  • CONTROLS_GLOBALIZATION_BEHAVIORS_ENABLED - Build with Globalization Behaviors
    (CultureChangeConditionBehavior, SetCultureActionBehavior)
  • CONTROLS_GRAPH_BEHAVIORS_ENABLED - Build with Graph Behaviors
    (BarGraphBehavior, LineGraphBehavior)
  • CONTROLS_HOVER_EVENT_ENABLED - Activate hover events from Control Touch Session
  • CONTROLS_KEYBOARD_BEHAVIORS_ENABLED - Build with Keyboard Behaviors
    (KeyboardActionBehavior, KeyboardBehavior)
  • CONTROLS_MAP_BEHAVIORS_ENABLED - Build with Map Behaviors
    (GeocodingBehavior, MapActionBehavior, MapBridgeBehavior, MapLocationActionBehavior, MapNavigationActionBehavior, NavigationInstructionViewBehavior)
  • CONTROLS_MENU_BEHAVIORS_ENABLED - Build with Menu Behaviors
    (MenuItemBehavior, MenuScreenActionBehavior, MenuScreenBehavior, PageIndicatorActionBehavior, PageIndicatorBehavior)
  • CONTROLS_MESH_BEHAVIORS_ENABLED - Build with Mesh2D Behaviors
    (TransformMesh2DBehavior)
  • CONTROLS_MIXEDREALITY_BEHAVIORS_ENABLED - Build with Mixed Reality Behaviors
    (NavigationPathBehavior, PoiBehavior, PoiConfigBehavior, PoiManagerBehavior, PoseTrackingBehavior)
  • CONTROLS_PARTICLE_EMITTER_BEHAVIORS_ENABLED - Build with Particle Emitter Behaviors
    (ParticleEmitterBehavior)
  • CONTROLS_PLUGIN_CONFIGURATION_ENABLED - Use the output from the "Used Behaviors Plugin". See Used Behaviors Plugin.
  • CONTROLS_ROLL_BEHAVIORS_ENABLED - Build with Roll Behaviors
    (RollBehavior)
  • CONTROLS_SCRIPTING_BEHAVIORS_ENABLED - Build with Scripting Behaviors
    (EnableScriptingSystemBehavior)
  • CONTROLS_SCROLL_LIST_BEHAVIORS_ENABLED - Build with Scroll & List Behaviors
    (ScrollViewBehavior, ListBehavior, SnapListItemConfigurationBehavior, SnapListItemExtensionBehavior, SubListBehavior, ScrollableEventActionBehavior, ScrollbarBehavior)
  • CONTROLS_SELECTION_GROUP_BEHAVIORS_ENABLED - Build with Selection Group Behaviors
    (ChangeSelectionActionBehavior, SelectionConditionBehavior, SelectionGroupBehavior)
  • CONTROLS_SLIDER_BEHAVIORS_ENABLED - Build with Slider Behaviors (Slider, CircularSlider, Dial)
    (SliderBehavior, CircularSliderBehavior, DialBehavior)
  • CONTROLS_STREAMING_BEHAVIORS_ENABLED - Build with Streaming Behaviors
    (VideoStateConditionBehavior, VideoStreamActionBehavior, VideoStreamBehavior)
  • CONTROLS_USED_BEHAVIORS_CONFIG_PATH - Path to the output file of the "Used Behaviors Plugin". Flag is only available if flag CONTROLS_PLUGIN_CONFIGURATION_ENABLED is active. See Used Behaviors Plugin.
