MONITOR_BLOCK_UNTIL_CONNECT enables waiting until host connects to target.
MONITOR_CANDERA_CUSTOM_EXPERIMENTS enables custom global experiments.
MONITOR_CANDERA_PERFORMANCE_RECORDER_ENABLED defines whether or not to expand performance recocrder macros.
MONITOR_CANDERA_PERFORMANCE_RECORDER_GENERATION_DIR sets the location of the Candera performance recorder generation.
MONITOR_CANDERA_PERFORMANCE_RECORDER_TEMPLATE_DIR sets the location of the Candera performance recorder template.
MONITOR_COM_TYPE sets the type of monitoring connection.
MONITOR_FRAME_DEBUGGER_ENABLED enables basic frame debugger (frame timeline capture, single step mode, no OpenGL specific features).
MONITOR_FRAME_DEBUGGER_OPENGL_CAPTURE_ENABLED enables OpenGL specific Frame Debugger features.
MONITOR_MEMORYPOOL_BINARY_LOGGING_ENABLED activates the Memory Pool activity logging.
MONITOR_MEMORYPOOL_BINARY_LOGGING_FILENAME location where the log-file will be generated. The extension has to be *.membin.
MONITOR_RECORDING_2D_CALLS_ENABLED enables all 2D driver calls.
MONITOR_RECORDING_OPENGL_ENABLED enables all OpenGL Recorder (e.g. Timing Recorder of OpenGL).
MONITOR_SINGLE_STEP_INTERVAL sets the time in milliseconds that is used when incrementing the animation time in single-step mode.
MONITOR_TCPIP_ADDRESS sets the adress of target device which is a server. Therefore this is the listening ip 0.0.0.0 and enables listening to any address.
