“Unexpected” Allocations
VRAM Memory Pool
  • [Applicable for platforms Traveo, Traveo II, RH850]
  • Why in the VRAM 4 buffers are allocated for render buffers of a single Render Target?
  • What happens:
    • During a transition first scene is unloaded, next scene is loaded
    • In case of startup, the first scene is the only one existing
    • Default Behavior of Courier:
      • when the last View on a Render Target is unloaded, the Render Target is also unloaded
    • The VramAllocator does never immediately free the memory, because the GPU might still write to it (Note: GPU runs
    • asynchronously to the CPU)
    • -> New 2 buffers are allocated when the second scene is loaded
  • How to fix it?
  • Send on startup a ViewPlaceholderReqMsg
    • increases the reference counter on Render target.
    • The message has two parameters
    • ViewId: this is a "reference" view which is used to determine the render target object
    • Load: true means to increase the reference count, false would decrease it (removes this placeholder from the internal list)
  • Alternatively, you can also use a dummy scene with just a camera
    • This view would be always active and never unloaded.
Asset Cache
  • From the Memory Pool Analysis Sheet:
16384
C:\CGI-Studio_3.10\cgi_studio_candera\src\CanderaAssetLoader\AssetLoaderBase\AssetCache.cpp(38)
  • -> This is the cache used by the Asset Loader when copying images from flash to RAM
  • Most or all images are directly rendered from flash
  • The cache size is best practice for many platforms, but not when flash is directly accessible!
  • -> Proposal: If flash is directly accessible, reduce the cache
    • E.g., to 1 kB (you win 15 kB!)
  • CMake flag CANDERA_ASSET_CACHE_SIZE
