Candera flags
  • CANDERA_3D_CANVAS_ENABLED defines whether Candera3D Canvas is enabled or not.
  • CANDERA_ASSETLOADER_MEMORYPOOL_ENABLED defines whether asset loader objects are allocated from a dedicated memory pool or not.
  • CANDERA_ASSETLOADER_WORKER_THREAD_ENABLED uses an own worker thread for asynchronous asset loader calls.
  • CANDERA_ASSET_CACHE_SIZE defines the buffer size for asset caching. A memory chunk of this size will be allocated for caching asset chunks for fast access.
  • CANDERA_ASSET_DECOMPRESSION_CHUNK_SIZE defines the chunk buffer size for asset decompression. This value is only relevant for File Asset Repositories.
  • CANDERA_BIDIRECTIONAL_TEXT_ENABLED defines whether bidirectional text parsing is enabled or not.
  • CANDERA_CUSTOM_LOCALIZER_ENABLED defines whether or not a custom Localizer must be used instead of the DefaultLocalizer.
  • CANDERA_EXTERNAL_SHADER_BUILDER_HEADER_INCLUDE includes path to external CPP header file, referenced by CANDERA_EXTERNAL_SHADER_BUILDER_HEADER_PATH.
  • CANDERA_EXTERNAL_SHADER_BUILDER_HEADER_PATH defines path to external CPP header file with BUILD_SHADER macro definition, relative to Common/Internal/RenderDevice2DOver3D/.
  • CANDERA_EXTERNAL_SHADER_BUILDER_SOURCE_PATH defines path to external CPP source file with binary shaders data, relative to Common/Internal/RenderDevice2DOver3D/.
  • CANDERA_FONTENGINE defines which font engine to use.
  • CANDERA_GLOBALIZATION_ENABLED defines whether globalization support is enabled or not.
  • CANDERA_LAYOUT_CLIPPING_ENABLED defines whether Candera2D layout clipping (setting a clipping rectangle for every render node) is enabled or not.
  • CANDERA_LAYOUT_ENABLED defines whether Candera dynamic layout is enabled or not.
  • CANDERA_LEGACY_BEHAVIORS_ENABLED builds with legacy behaviors.
  • CANDERA_MULTILINE_TEXT_ENABLED defines whether multiline texts are enabled or not.
  • CANDERA_SCRIPTING_ENABLED defines whether CanderaScripting sources shall be included or not.
  • CANDERA_TEXTENGINE_DLIG_FEATURE_ENABLED defines if Discretionary Ligatures (dlig) are enabled or not (support only in Harfbuzz for now).
  • CANDERA_TEXTENGINE_MEMORYPOOL_ENABLED defines whether text engine objects are allocated from a dedicated memory pool or not.
  • CANDERA_TEXTENGINE_NATIVE_LINEHEIGHT_ENABLED defines whether or not the native line height metrics of the font engine is used. If disabled then 120% of EM size is applied as line height which is compatible with Adobe.
  • CANDERA_TEXTENGINE_WORKER_THREAD_ENABLED uses an own worker thread for asynchronous textrender calls. It uses the update routine (single threaded) when this flag is disabled.
  • CANDERA_TEXTSHAPER selects the text shaper.
  • CANDERA_TRANSITIONS_ENABLED defines whether CanderaTransitions sources shall be included or not.
  • CANDERA_VIDEO_MEMORY_STATISTIC_ENABLED activates support for video memory allocation statistics. ATTENTION: Activated memory statistics may decrease performance!
  • CANDERA_ASSET_ADDRESS is the address for eMMC / QSPI flash access
  • CANDERA_ASSET_ADDRESS_USE_DEFAULT defines the default address for flash access
      • 0x00000000  for eMMC
      • 0x2000000 for QSPI
  • CANDERA_ASSET_LOCATION is the asset location chosen by the user at CMake configure time
  • CANDERA_BUILD_SCHOST defines whether SCHost library and DLL are built or not
  • CGIDEVICE_BSP_LIBRARY_PATH defines the path to directory including libfbdev.a (for RCarD3, RCarH3 and RCarM3 devices)
  • CGIDEVICE_EGL_INCLUDE_PATH defines path to EGL folder
  • CGIDEVICE_GFX_LIBRARY_PATH defines the path to graphics libraries (for RCarD3, RCarH3 and RCarM3 devices)
  • CGIDEVICE_OPENGL_EGL_CONFIG_PATH defines the path to OpenGL and EGL configuration files (for RCarD3 and RCarH3 devices)
  • CGIDEVICE_OPENGL_ES_30_INCLUDE_PATH defines the path to GLES3 folder
  • CANDERA_EXTERNAL_SHADER_BUILDER_USAGE_DEFAULT defines whether the default paths for external shader builder for 2DOver3D shaders are used or not."
