Running the CGI Player Demo Application on Traveo2
Download the Application
To download and debug the application you need a Green Hills probe (or IAR Systems I-jet probe) that is configured accordingly for your Infineon Traveo II board.
Executable Application
Green Hills
  • In MULTI launcher select "Components" -> "Open debugger" and choose the application from your build folder with extension .ghsmc.
  • Then press "D" (for "Detect"), once the script detects the board and sets all needed variables in the debugger window three new symbols will be available "F" "V" and "E".
  • Press "F" (for "Flashing") the application on the board.
  • Press "F5" on keyboard or "Go on Selected Items" ("Play") button to run the application.
"surface_blit_display_basic" graphics driver sample’s project has to be set as WorkingDir (Workspace) in MULTI launcher.
IAR Embedded Workbench
Binary directory contains two IAR EW projects under "iar_projects" (for flash only and/or flash and debug).
  • Open the EW workspace *.eww from the project in which you will select e.g. .eww.
  • Rebuild ("Project" ->"Rebuild All") cm0plus project.
  • Press ("Project" ->"Download and Debug") to flash the executable.
  • Press "F5" on keyboard or "Debug -> Go" to run the application.
Loading the asset
The CGI Player demo application uses an asset file which could be added by the linker or loaded from external flash. CGIDEVICE_ASSET_LOCATION holds that information (options: Monolith or Flash).
In case of Monolith option for CGIDEVICE_ASSET_LOCATION, the asset file will be loaded to internal flash together with the application. You have to select the asset file in CMake via the variable ASSET_TARGET_LOCATION before you build the application.
In case of Flash option for CGIDEVICE_ASSET_LOCATION, the asset file will be loaded during startup of the application. A prerequisite is that it must be flashed to the external flash (Hyperflash) on the board before executing the app.
This is the only available option for IAR Embedded Workbench toolchain.
