Building Own Application for Traveo2
Generate Makefiles with CMake
For general information about CGI Studio Build System and CMake properties available to configure Candera applications, refer to CGI Studio Build System. To configure and generate makefiles for compiling the CGI CourierSampleAppLight, follow the steps below:
    • Folder containing top-level "CMakeLists.txt", e.g. or \ LightPlayer
  2. Point CMake to build directory
  3. Configure
    • Specify MinGW Makefiles (or Ninja) as generator for the project
  4. Select the toolchain-file from the delivery based on your target. (adapt for your toolchain installation and application specific needs)
    • (for MULTI) cgi_studio_devices\src\Traveo2\ToolchainFiles\MULTI-toolchain-TraveoII_C_6M.txt or cgi_studio_devices\src\Traveo2\ToolchainFiles\MULTI-toolchain-TraveoII_C_4M.txt
    • (for IAR EW) cgi_studio_devices\src\Traveo2\ToolchainFiles\IAR-toolchain-TraveoII_C.txt)
    • Press Configure
  6. Press Generate
Building Application
After generating your cmake files, in Command Prompt simply navigate to the specified build directory and type "mingw32-make" (or "ninja") to start the build.
The output executable file can be found in your build directory.
Load and debug the application as described in the previous chapter.
