New Script
A new script is created using the "New Script" menu item.
Selecting the item will prompt a dialog to enter a name.
Depending on the option 'Code Template' in the dialog, the newly created script will either be empty (Code Template: Empty), contain commonly used callback functions (Code Template: Basic), or contain the full set of callback functions for the user to implement (Code Template: Full).
Alternatively, scripts can be added to a solution via "Add" > "New item" option by using the Solution Explorer context menu.
Scripts will show up in the Solution Explorer and the Scripts section of the Toolbox with the postfix ".lua".
