File Menu
offer commands that allows to control how the application runs.
Options:
  • Start application ... - opens a dialog window which allows to configure and start the application.
  • The configuration options are:
    • Device: allows to choose the device from a dropdown list.
    • Asset Library Path: allows to set the full path to the asset.
    • Mode: allows to decide if the Player will be started as an application or by a script.
    • Application Mode
      • Application: allows to set the path to the Player executable.
      • Parameter: allows to set a parameter which shall be passed to the application.
    • Script Mode
      • Script: allows to set the path to the script.
      • Parameter: allows to set a parameter which shall be passed to the script.
      • Wait for script to finish: configures whether the panel should wait or not until the script has finished.
  • Attach - attaches the panel to a running Player.
  • Settings... - opens a dialog window which allows to configure the Cgi Panel.
    • General
      • Show first scene: enables that the first scene is automatically loaded at start time.
      • On Panel close - Application shutdown: if enabled the applications started by the Player will be shutdown automatically.
    • Panel Network Connection
      • Connection timeout (ms): sets a timeout for network connection.
      • IP-Address: sets a custom IP address of the network control.
      • TCP/IP - Port: sets a custom TCP/IP port of the network control.
    • Monitoring
      • Use customized monitoring settings: allows to set custom setting for the monitoring (TCP/IP-Port, Serial-Port and Serial-Baudrate).
    • Recording
      • Snapshot directory: defines the location where the snapshots shall be stored.
      • Asset directory: defines the location of assets which will be loaded.
  • Open workspace: opens in File Explorer the directory were the CGIPanel.exe resides.
  • Exit: closes CGI Panel.
