Plugin Options
Plugins Available
Available plugins are displayed under  [ Plugins ] in the Preferences dialog.
All available plugins are enabled by default. To disable a plugin, click the button to the right of its properties. When the button displays "Enable," the plugin is disabled.
Plugin Name Description Note
AstcBitmapConverter This is an ASTC bitmap converter. Converts RGBA unsigned byte data to ASTC RGBA. ー
Used Behavior plugin This plugin extracts the type names of all behaviors included in the solution. When generating assets, a CMake file is generated according to the plugin's specific settings. Details
Cgi-Studio Image Update This is a plugin for the Image Update function. Details
CommandLinePlugin This is a plugin for executing commands when generating assets. Details
List Property Editor
This is a plugin for the List Editor. The List Editor can be used with controls such as BarGraph and LineGraph.
Details
SpecificationPlugin
This is a plugin for Define application specification. Define application specification is required to link data binding sources with Scene Composer.
Details
DataBindingEditorPlugin
This is a plugin for the Data Binding bind icon and Live Preview panel.
Details
Dirty Area Dependency Plugin This is a plugin for the Dirty Area Management (DAM). Details
ExecutableGenerationPlugin
This is a plugin for executing scripts when generating assets.
Details
ExternalResourceContainerPlugin This is a plugin for the Referencing external resource function.
Details
iMX6 Shader Compiler This is a shader compiler for iMX6. Details
RCarD3 Shader Compiler This is a shader compiler for RCarD3. Details
RZA1HBitmapConverter This is a bitmap converter for RZA1H. ー
Cgi-Studio Transrator This is a plugin for Localization. Details
Traveo2BitmapConverter This is a custom bitmap converter for Traveo2. Details
Plugin-Specific Settings
ASTC Configuration
Setting item Description
Compression Speed
The Compression Speed can be set to one of five levels.
Behavior Config Generation
Behavior Configuration Enabled
If enabled, a CMake file containing the configuration of all behaviors included in the solution will be generated.
Destination path
Set the path to the CMake file in the CMake flag "CONTROLS_USED_BEHAVIORS_CONFIG_PATH".
Commnad Line
Command Line
Sets the command to be executed when generating assets.
Include in asset
If enabled, information about Dirty Area Management will be output to the asset.
Generated output format
Set the output format from three options (Text, Binary, or Binary program).
Custom command line string
Enter the tool or identifier to execute in command line format. This setting can only be set when the output format is Binary or Binary program.
Translator
Export always If enabled, all translated text will be included in asset.
Export Only Used Translatable Texts If enabled, only translated text used in behaviors, etc. will be included in assets.
Enable Language Pack Source Monitoring If enabled, Language Pack Source files will be monitored.
Language Pack Source Set the Language Pack Source to be monitored.
Solution Path The root path of the solution will be displayed.
Changes to Plugin-Specific settings will take effect after restarting Scene Composer.
