Default Adjustments
An adjustment is specified by a mode and a delta. Mode defines the way of the distortion, delta defines the amount. The following modes are available:
  • Parallelogram
  • Trapezoid
  • Pin balance
  • Pincushion
  • Shift
  • Width
  • Height
  • Rotation (around bitmap image center point)
For each reference point and corresponding shift vector, the adjustment is computed and applied. The resulting shift vector is again cached in the warping library. This way of implementation allows incremental adjustments.
Following are tables detailing supported adjustments:
Mode
Direction
Trapezoid Parallelogram Pincushion Pin balance
Up
Down
Left
Right
Mode
Direction
Height Width Rotation Shift
Up
Down
Left
Right
