A Simple Custom Type Editor
Creating a custom type editor
To run this example you must first create a C# project that refrecnes FTC.SDKInterface.dll. The resulting dll from your project (along with any non .NET dependecies) must be placed in the Plugins directory in the FTC install location.
The Plugin class.
The first step is to create a class that implements the ICustomTypeEditor interface. This is the type that will be instantiated by Scene Composer whose methods will be called to handel custom type specific actions.
 public class CustomTypeEditorPlugin : ICustomTypeEditor
Implementing IPlugin
Next we must implement the IPluginService interface members.
 public string Name
    get { return "Custom Type Editor"; }
 public string Description
    get { return "Sample custom type editor"; }
 public string Version
    get { return "1.1"; }
 public void Initialize(IUnityContainer unityContainer)
Specifying what types are supported
We implement the SupportedTypes member of the ICustomTypeEditor. This property defines the name of the custom types supported by the plugin. These names will be passed back to the plugin wherever the type must be identified. Also these are the names that should be used in the meta info file.
 private const string CustomTypeName = "CustomTypeEditor";
 private const string AnotherCustomTypeName = "AnotherCustomTypeEditor";
 public IEnumerable<string> SupportedTypes
    get
       yield return CustomTypeEditorPlugin.CustomTypeName;
       yield return CustomTypeEditorPlugin.AnotherCustomTypeName;
Defining the values of the type
Next we implement value related methods.
The GetDefaultInternalValue will return the default value for a type, for our types the defaults are "0;" and "0". The first custom type is a complex type that has two components separated by ';' the first component must be an integer, while the second will be a simple string. The second custom type is a simple integer value.
 public string GetDefaultInternalValue(string type)
    switch (type)
       default:
          throw new ArgumentException("Unsupported type '" + type + "' in plugin " + this.Name);
       case CustomTypeEditorPlugin.CustomTypeName:
          return "0;";
       case CustomTypeEditorPlugin.AnotherCustomTypeName:
          return "0";
The IsInternalValueValid method validates whether the value passed as argument is valid for the type.
 public bool IsInternalValueValid(string type, string value)
    int intValue;
    switch (type)
       default:
          string[] tokens = value.Split(';');
          return tokens.Length == 2 && int.TryParse(tokens[0], out intValue);
          return int.TryParse(value, out intValue);
The GetAssetValue converts the internally stored value for a type to an asset compatible value. This value is dependant on the consumer of the property. For our example we will use the same strig as the internal value.
 public string GetAssetValue(string type, string value)
    switch (type)
       default:
          return value;
          return value;
Last we must define the ShowEditValueDialog method that is used for the actual value editing. We assume the existence of CustomEditor dialog window which will be detailed later, that has two textboxes that out custom editor can access.
The method calls the dialog, and collects the values from the textboxes. If the user hits ok in the dialog then the method will return true, otherwise it will return false, and the new value will not be saved.
 public bool ShowEditValueDialog(string type, string initialValue, out string value)
    int intValue;
    var dlg = new CustomEditor();
    switch (type)
       default:
          string[] tokens = initialValue.Split(';');
          if (tokens.Length == 2)
             if (int.TryParse(tokens[0], out intValue))
                dlg.textBox0.Text = tokens[0];
             dlg.textBox1.Text = tokens[1];
          if ((bool)dlg.ShowDialog())
             string newValue = dlg.textBox0.Text + ";" + dlg.textBox1.Text;
             if (this.IsInternalValueValid(type, newValue))
                value = newValue;
                return true;
          break;
          if (int.TryParse(initialValue, out intValue))
             dlg.textBox0.Text = initialValue;
          dlg.textBox1.Visibility = System.Windows.Visibility.Collapsed;
          if ((bool)dlg.ShowDialog() && this.IsInternalValueValid(type, dlg.textBox0.Text))
             value = dlg.textBox0.Text;
             return true;
          break;
    value = initialValue;
    return false;
Defining the Dialog Window
Implicitly any dialog show in scene composer will use the same look and feel for the controls. For the window however, an explicit style must be set to give it the Scene Composer look and feel, that style is named 'DialogWindow'
 <Window x:Class="CustomTypeEditor.CustomEditor"
      xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
      xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
      Style="{DynamicResource DialogWindow}" ...>
The full code for the example:
CustomTypeEditorPlugin.cs
 using System;
 using System.Collections.Generic;
 using System.Linq;
 using System.Text;
 using System.Windows.Controls;
 using FTC.SDKInterface.Plugins;
 namespace CustomTypeEditor
       public string Name
          get
       public void Initialize()
         switch (type)
            default:
               return value;
               return value;
          switch (type)
             default:
                return "0;";
                return "0";
          int intValue;
          switch (type)
             default:
          int intValue;
          switch (type)
             default:
                      value = newValue;
                      return true;
                break;
                   return true;
                break;
          return false;
CustomEditor.xaml
   The resources for controls are implicitly inherited from the application, so all the controls should look the same as in scene composer.
   To have a dialog window that looks the same as Scene Composer's you must specify the DialogWindow style resource.
   Other useful resource keys are :
      - NormalBrush - Used for the background of some items
      - LightBrush - Used for the background of some items
      - TextBrush - Used for the text color.
      - NormalBorderBrush - The normal border color of a control
      - HoverBrush - used for highlighting the hover over an element
      - ControlBackgroundBrush - used for the background of a control
      - SelectedBackgroundBrush - used to highlight a selected element
      - WindowBackgroundBrush - used for the color of the window background
    Title="Custom Type Editor" Height="172" Width="249" KeyDown="OnKeyDown" ResizeMode="NoResize" WindowStartupLocation="CenterScreen">
    <Grid>
      <Button Margin="34,99,0,0" Name="button1" HorizontalAlignment="Left" Width="76" Click="OnOkButtonClick" Height="23" VerticalAlignment="Top">OK</Button>
      <Button HorizontalAlignment="Right" Margin="0,99,21,0" Name="button2" Width="75" Click="OnCancelButtonClick" Height="23" VerticalAlignment="Top">Cancel</Button>
      <TextBlock Height="25" HorizontalAlignment="Left" Margin="12,33,0,0" Name="label0" VerticalAlignment="Top" Width="76">Number:</TextBlock>
      <TextBlock Height="25" Margin="12,64,0,0" Name="label1" VerticalAlignment="Top" HorizontalAlignment="Left" Width="76">Text:</TextBlock>
      <TextBlock Height="25" Margin="12,-1,0,0" Name="label4" VerticalAlignment="Top" HorizontalAlignment="Left" Width="120">Custom Type:</TextBlock>
      <TextBox Height="25" Margin="86,33,0,0" Name="textBox0" VerticalAlignment="Top" HorizontalAlignment="Left" Width="120" />
      <TextBox Margin="86,64,0,0" Name="textBox1" Height="25" VerticalAlignment="Top" HorizontalAlignment="Left" Width="120" />
   </Grid>
</Window>
CustomEditor.xaml.cs
 using System;
 using System.Linq;
 using System.Text;
 using System.Windows;
 using System.Windows.Data;
 using System.Windows.Documents;
 using System.Windows.Input;
 using System.Windows.Media;
 using System.Windows.Media.Imaging;
 using System.Windows.Navigation;
 using System.Windows.Shapes;
    public partial class CustomEditor : Window
       public CustomEditor()
          InitializeComponent();
       private void OnOkButtonClick(object sender, RoutedEventArgs e)
          this.DialogResult = true;
          this.Close();
       private void OnCancelButtonClick(object sender, RoutedEventArgs e)
          this.Close();
       private void OnKeyDown(object sender, KeyEventArgs e)
          switch (e.Key)
             case Key.Escape:
                this.Close();
                return;
             case Key.Enter:
                this.OnOkButtonClick(this, new RoutedEventArgs());
                return;
