A plugins that defines a custom menu
Creating a plugin that displays a custom menu
To run this example you must first create a C# project that refrecnes FTC.SDKInterface.dll, Feat.UIComposition.dll and Feat.Core.dll. The resulting dll from your project (along with any non .NET dependecies) must be placed in the Plugins directory in the FTC install location.
The Plugin class.
The first step is to create a class that implements the IPluginService interface. This is the type that will be instantiated by Scene Composer.
  public class CustomMenuPlugin : IPluginService
Implementing IPlugin
Next we must implement the IPluginService interface members.
 public string Name
   get { return "Custom Menu Definition"; }
 public string Description
    get { return "A plugin that defines a custom menu"; }
 public string Version
   get { return "1.0"; }
 public void Initialize(IUnityContainer unityContainer)
     //register the menu config interface
     var loader = unityContainer.Resolve<IConfigurationManager>().RegisterConfigurationInterface<IMenuPluginConfig>();
Config and commands interfaces
We will need to provide an interface derived from IConfiguration and an interface derived from ICommandContainer that defines the available commands.
 public interface IMenuPluginConfig : IConfiguration
   ObservableCollection<string> Data { get; set; }
 public interface ICustomPluginCommands : ICommandContainer
   ManagedCommand AddItem { get; }
   ManagedCommand RemoveItem { get; }
Then in the Initialize method:
Register the menu config interface
 loader.ConfigLoaded += loader_ConfigLoaded;
Register the menu commands
  var cmdCollection = new CommandDefinitionCollection<ICustomPluginCommands>()
      c=>c.AddItem,
      new ManagedCommand()
         ExecuteHandler = o=>
            var data = loader.Instance.Data;
            data.Add("Item " + data.Count);
         Metadata = new MetadataCollection()
            new MainMenuOption()
               MenuPath = new MenuPath() { MenuConstants.File_1, "Items", "Add" },
      c=>c.RemoveItem,
         CanExecuteHandler = o=> loader.Instance.Data.Any(),
            data.RemoveAt(0);
               MenuPath = new MenuPath() { MenuConstants.File_1, "Items", "Remove" },
 cmdCollection.RegisterAll(unityContainer.Resolve<UICommandManager>());
And register a custom menu definition to hold the item list
  var menuDefMgr = unityContainer.Resolve<MenuDefinitionManager>();
  menuDefMgr.RegisterMenuDefinition(new CustomMenuDefinition()
     MenuPath = new MenuPath() { MenuConstants.File_1, "Items", "RegItems" },
  loader.Instance.Data.CollectionChanged += Data_CollectionChanged;
The full code for the example:
CustomMenuPlugin.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using FTC.SDKInterface.Plugins;
using System.Collections.ObjectModel;
using Feat.UIComposition.Commanding;
using Feat.UIComposition.Config;
using Feat.UIComposition;
using Feat.UIComposition.Menus;
using FTC.SDKInterface.Constants;
namespace UIPlugins.CustomMenu
     public string Name
        get { return this.Description; }
     public IEnumerable<int> FeatureIds
        get { return null; }
     public FTC.SDKInterface.Services.IUnityContainer UnityContainer { get; set; }
     public void Initialize(FTC.SDKInterface.Services.IUnityContainer unityContainer)
        this.UnityContainer = unityContainer;
              c=>c.AddItem,
              c=>c.RemoveItem,
                    data.RemoveAt(0);
     void Data_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
        var cmdContainer = this.UnityContainer.Resolve<UICommandManager>().GetCommandContainer<ICustomPluginCommands>();
        cmdContainer.RemoveItem.RaiseCanExecuteChanged();
     void loader_ConfigLoaded(object sender, ConfigLoadedEventArgs<IMenuPluginConfig> e)
        if (!e.ConfigLoadedSuccessfully)
           e.Instance.Data = new ObservableCollection<string>();
CustomMenuDefintion.cs
using System;
using System.Linq;
using System.Text;
using System.Windows.Controls;
using Feat.CAL.Services;
using Feat.Utils;
using System.Windows;
  class CustomMenuDefinition : MenuDefinitionBase
     protected override IMenuItemManager CreateMenuItemManger(MenuManager menuManger)
        return new CustomMenuManager(this);
     public override string UniqueName
        get { return this.GetType().AssemblyQualifiedName + this.MenuPath; }
  class CustomMenuManager : IMenuItemManager
     public ObservableCollection<string> items;
     private IDialogSvc dialogSvc;
     public CustomMenuDefinition Definition { get; set; }
     public CustomMenuManager(CustomMenuDefinition cmDef)
        this.Definition = cmDef;
        this.dialogSvc = this.Definition.UnityContainer.Resolve<IDialogSvc>();
        this.items = this.Definition.UnityContainer.Resolve<IConfigurationManager>().
           GetConfiguration<IMenuPluginConfig>().Data;
        items.CollectionChanged += items_CollectionChanged;
     void items_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
        this.Invalidate();
     MenuItem rootMenuItem;
     public void Attach(MenuManager menuMgr, ItemsControl parentMenuItem, object startingSibling)
        this.rootMenuItem = new MenuItem()
           Header = "ItemList"
        parentMenuItem.Items.Add(rootMenuItem);
        this.Invalidate();
     public bool IsItemVisible
        get
           return this.items.Any();
     public event EventHandler HasItemsChanged;
     public void Invalidate()
        this.rootMenuItem.Items.Clear();
        items.
           Select(s => new MenuItem()
              Header = s,
              Command = new ManagedCommand()
                 ExecuteHandler = o =>
                    this.dialogSvc.ShowMessageBox(s, s, MessageBoxButton.OK, MessageBoxImage.Information)
           ForEach(i => this.rootMenuItem.Items.Add(i));
        if (this.HasItemsChanged != null)
           this.HasItemsChanged(this, EventArgs.Empty);
