Build (Global)
Via the Builds (Global) tab it is possible to edit variables that are used in the building of all applications.
Each variable will have a string name, a string description, and a value. This value will be either of type file (ie. Filename), path (ie. Filepath), or value (ie. string, char, int, etc.). If Type:Value is selected, the file selection button will be greyed out.
To add or delete variables for a build, use the +/- buttons on the right-hand side of the variables table.
