FeatStd TCP/IP reimplementation
The concept of TCP/IP has been reworked. There are two new classes available: TcpServer and TcpClient. The server can open a port to listen to. A connection to such a server will return a stream which is of type TcpClient. The client can then be used for communication. This concept allows multiple connections at the same time with the convenient stream interface. The old TcpIp interface is still available and extended by an own socket concept. Using the old functions work completely equal to the old concept. Therefore, only one connection to the server is allowed. After the connection is lost, it cannot be reused. A shutdown is required.
The old TcpIp will be deprecated in future versione with an upgrade of Monitor to the new concept.
