Behaviors Changes
Converted 2D/3D behaviors to "mixed" behaviors
Several behaviors had a dedicated 2D and 3D variant. Such behaviors have been cleaned up and replaced by a mixed behavior providing a 2D or 3D implementation based on the node attached to. The 2D and 3D specific behaviors have been deprecated, a solution conversion will automatically convert existing Scene Composer solutions.
Affected behaviors:
  • ArcAlignBehaviorBase2D deprecated, replaced by ArcAlignBehavior
  • TouchIndicationBehavior2D and TouchIndicationBehavior3D deprecated, replaced by TouchIndicationBehavior
  • PositionProcessValueBehavior2D and PositionProcessValueBehavior3D deprecated, replaced by PositionProcessValueBehavior
    • property TranslationAxis has been renamed to TranslationAxis2D, a new property TranslationAxis3D has been introduced
  • RotateProcessValueBehavior2D and RotateProcessValueBehavior3D deprecated, replaced by RotateProcessValueBehavior
    • property RotationAxis added
  • ScaleProcessValueBehavior2D deprecated, replaced by ScaleProcessValueBehavior
    • property IsScalingAlongXEnabled has been renamed to ScaleAlongX
    • property IsScalingAlongYEnabled has been renamed to ScaleAlongY
    • new property ScaleAlongZ added
    • property VectorXY has been renamed to ScaleVector2D
    • new property ScaleVector3D added
  • TranslateProcessValueBehavior2D and TranslateProcessValueBehavior3D deprecated, replaced by TranslateProcessValueBehavior
    • property VectorXY (Vector2) has been replaced by MultipliedVector (Vector3)
  • TrackPositionProcessValueBehavior2D and TrackPositionProcessValueBehavior3D deprecated, replaced by TrackPositionProcessValueBehavior
  • AlphaProcessValueBehavior2D and AlphaProcessValueBehavior3D deprecated, replaced by AlphaProcessValueBehavior
  • ColorActionBehavior2D deprecated, replaced by ColorActionBehavior
  • EffectColorBehavior2D deprecated, replaced by EffectColorBehavior
  • ImageActionBehavior2D deprecated, replaced by ImageActionBehavior
    • property Texture has been added
  • SetImageBehavior2D deprecated, replaced by SetImageBehavior
    • new property Textures added
  • TextBehavior2D deprecated, replaced TextBehavior
  • ZoomProcessValueBehavior2D deprecated, replaced by ZoomProcessValueBehavior.
  • ScrollbarBehavior2D and ScrollbarBehavior3D deprecated, replaced by ScrollbarBehavior
  • SwitchActionBehavior2D deprecated, replaced by SwitchActionBehavior
  • SwitchImageProcessValueBehavior2D deprecated, replaced by SwitchImageProcessValueBehavior
    • property RenderNode has been renamed to TargetNode
  • SwitchRangeProcessValueBehavior2D deprecated, replaced by SwitchRangeProcessValueBehavior
Further changes:
  • Constructor ClippingSetterTraverser(const Candera::Rectangle& clippingArea, Candera::Node2D& node) has been deprecated
    • Please use ClippingSetterTraverser(const Candera::Rectangle& clippingArea, Candera::AbstractNodePointer& node) instead
  • PropertyProviderBehaviorBase: properties Texture, Appearance, Value have been added
ControlTouchSession considers Camera for sorting
In the past the camera was not considered by the touch handling. This resulted in ambiguous touched controls.
The ControlTouchSession has to sort behaviors according their "visual" order to assure, that touch inputs are forwarded to the "nearest" touchable behaviors. For this purpose a sub-struct ControlTouchSession::TouchedBehavior has been introduced. The camera will be used to retrieve the according Candera::RenderTarget. Consequently HW layer order, SW Layer order, surface id and camera sequence number are considered during sorting of behaviors.
Each behavior-camera pair will be treated separately, thus a behavior rendered by two cameras will be distinguished for each camera.
Beside the internal handling in the ControlTouchSession also the touch related events (TouchEvent, ClickEvent, PressedEvent, DragDropEvent and HoverEvent) have been extended by a touched camera. The old constructors have been deprecated. Please use the one with the additional camera instead.
For the same reason also KeyboardFocusManager has been enhanced by new methods KeyboardFocusManager::SetFocused(const Candera::AbstractNodePointer& node, const Candera::AbstractCameraPointer& camera) and KeyboardFocusManager::GetFocusedCamera(). Please also use the SetFocused with the extra camera parameter in future.
Implementation of geometric and tab order focus navigation
A new event class KeyboardFocusNavigationEvent has been added to reflect navigation input like a rotary input to navigate between the visual controls. Furthermore the controls will use the new RegisterNavigation and DeregisterNavigation interface of the KeyboardFocusManager to register themselves for the navigation.
An interface has been added to extend the ControlTouchSession by gesture detectors
The detection of Click, press/release and drag&drop has been transformed into such a gesture detector. Futhermore, a gesture detector for swipe/flick and a gesture detector for transformations (rotate, pan and pinch) has been added.
Further minor changes
  • The return value of EventToMessageBridge::PostAsMessage has been changed to an enum type to reflect the exact outcome of the Post and to reduce the logging to errors only.
  • A Getter/Setter interface has been added to the ControlTouchSession to enable/disable the consumption of touch events by the ControlTouchSession. If the touch event is not consumed the Courier Touch Session will forward the touch messages to all widgets in the old touch handling style as message.
Property Provider supports Value
  • Property Provider (PropertyProviderBehavior) supports Value variant type
  • Send Value As Event has now PropertyReference that can be set to Other and point to Property Provider
SelectionGroup memory leak patched
Arithmetic operation behavior created
  • Arithmetic operation behavior (ArithmeticProcessValueBehavior) can be placed in ProcessValue chain to perform simple arithmetic operations on provided values.
  • It allows to perform addition, subtraction, multiplication and division operations on the passed value.
Send ChangeValueEvent on ProcessValueEvent behavior created
ValueBehavior supports broadcast feature
  • If enabled, ValueBehavior can now be used to forward input value even if it is the same as current value stored in the behavior, which is useful in broadcasting context
Provide Alignment adds Alignment property to the control
  • Provide Alignment can be used to add a controllable Alignment property to the control
  • AlignmentBehavior enables setting the horizontal and vertical alignment of a node.
Tracks angle on touch with regard to control's base point
  • Track angle behavior allows to obtain the angle (from the position of user interaction) with regard to control's base point, using the mathematical function atan2.
  • TrackAngleProcessValueBehavior listens to the touch of the selected node, returns the angle between pressing, moving and releasing.
DialBehavior supports Dial control
  • DialBehavior uses the angle obtained to calculate the rotation of the knob and change the position of the twisted knob to the value which is passed by ProcessValue function and ValueChangedEvent.
  • DialBehavior receives angle in ProcessValueEvent or value in ChangeValueEvent. It changes to appropriate rotation for knob. Transmits the changed value through events (ValueChangedEvent and ProcessValueEvent).
CircularSlider behavior supports CircularSlider control
  • CircularSliderBehavior draws a blending mask and rotates attached thumb.
  • Creates respective effects on runtime, according to Candera build options.
BreadcrumbBehavior supports breadcrumb control
  • A breadcrumb is used as a navigational aid in user interfaces.
  • It allows users to keep track and maintain awareness of their location.
  • Child nodes like Text, TextValue, TextButton or other nodes can react on TextEvent which is sent to child nodes.
  • Also BreadcrumbBehavior sends ValueChangedEvent to the state machine with the last value that has been received.
  • BreadcrumbActionBehavior allows you to control the breadcrumb.
Provide Appearance adds Appearance property to the control
  • Provide Appearance can be used to add a controllable 3D Appearance property to the control
  • Also extends Property Provider by Appearance.
Control State Behavior properly handles Disabled State
Previously it was possible to still interact disabled Control via Inputs. In 3.7 this is not happening anymore (e.g. a disaled button cannot be pressed).
Interpolate Value can be set to Instant Mode
Using the ChangeInterpolationModeEvent in a Behavior allows to control which Mode the Interpolate Value will operate.
Check Processed Value got extended by Almost Equal
Since comparing exact Float Values can lead to issues, the Check Processed Value Behavior now also supports checking if they are almost equal.
TrackPositionProcessValue can be set to only react on dragging the Knob
Normally the TrackPositionProcessValue would also react to Inputs outside of the Knob Node. By enabling the Drag On Knob Only property, this can be prevented.
Format String now supports all Variant Types
Format String did only support Integers and Float Values previously. This is now resolved.
DrawerActionBehavior / "Change Drawer State"
The DrawerActionBehavior has been created to support the new Drawer Control.
ParticleEmitterBehavior / "Particle Emitter"
The ParticleEmitterBehavior has been created to support the new Point Sprite Emitter Control.
Change Animation Mode by Event
The Animation Mode of InterpolateProcessValueBehavior can be changed by event now.
Input Range for MapProcessValueBehavior
The MapProcessValueBehavior has been enhanced by an input range for use cases where parts of the input range of the ProcessValueEvent shall be processed by several MapProcessValueBehavior. The input range is optional. If not set, then the input range is taken from the ProcessValueEvent.
RenderingEnabled Property now bindable
The property RenderingEnabled of behavior RenderNodeBehavior / "Render Node" is now bindable.
