New Controls
SpinBox Control
A spin box or spin button is a control that enables users to increase or decrease the number value by a specific increment (often by 1, 5 or 10) via clicking an up or down arrow button.
IconButton Control
Dial Control
A dial is used to set a value within a specified range or to select between different options which are represented by the value of the dial. The control knob changes the value when user touches and turns it. Degree of rotation corresponds to the desired value change. The dial snaps into its predefined positions defined by its step size.
Breadcrumb Control
It is possible to create your own control for your own needs (e.g. adding a separator between items), that will work properly with the breadcrumb. Remember to add BreadcrumbAction behavior in own control.
Circular Slider Control
Circular slider is a control that allows user to set the value using circular slide movement or directly indicate value on slider's bar. In default version the slider is a full circle, but using properties user easily can operate on e.g. quarter of the circle. In case of circular slider user can set the start angle and the end angle and map that to output value which is also customizable. Change of the value is indicated by slider's bar and (optional) thumb position.
Drawer Control
The Drawer is a control that allows to hide content that can be shown again when it is needed.
Point Sprite Emitter Control
The Point Sprite Emitter is control for 3D to make Particle Effects.
