Photoshop Exporter
Photoshop Exporter
  • Due to the recommendation to create documents with a 72 DPI resolution, the conversion will be done implicitly without any confirmation from the user. In this way, unexpected behavior which may be caused by internally conversion to 72 DPI will be avoided. The exporter scripts requires the resolution of the document to be 72 DPI in order to correctly compute and report the values of some properties of the layers. However, the working document is not affected, because the export (and the conversion) is performed on a copy of it (Mantis 6647 & Mantis 6795).
  • Trimming is no longer done on layers with transparent areas. The whole layer bounds are taken from Photoshop.
  • The position of the fonts is now calculated on export/import with little differences from the original (Mantis 6802 & 6646).
  • Photoshop exporter now exports text with the appropriate effect for Amber platform (Mantis 6821).
Known Issues
  • Photoshop character tracking is not supported, warning has been added in the export log.
  • The Photoshop Stroke layer style is not supported in SceneComposer.
