Candera Engine 3D
New Functions in Renderer
Renderer has new functions to activate and deactivate a camera (Renderer::ActivateCamera, Renderer::DeactivateCamera), to activate a clear mode (Renderer::ActivateClearMode), and scissor (Renderer::ActivateScissor).
Dirty Area Management
Renderer::RenderCamera now accepts a rectangle as the parameter that defines a dirty area. A dirty area denotes an area on the screen or render target in which the content has changed, thus only this area requires updating by the Renderer. The dirty area rectangle parameter defaults to the full size of the screen or render target. If the user provides his own dirty area rectangle, only this area will be cleared and drawn to. Objects whose bounding rectangle is outside the dirty area will be skipped. Generally speaking, the smaller the dirty area, the smaller the bandwidth required for clearing and drawing, and the more objects can be skipped.
This feature also adds the properties Renderer::Statistics::CulledNodesUsingDirtyAreaScissor and Renderer::Statistics::AverageDirtyAreaFactor. CulledNodesUsingDirtyAreaScissor denotes the number of objects that could be skipped by the Renderer due to their bounding rectangle being outside the dirty area. AverageDirtyAreaFactor denotes the average dirty area divided by the size of the screen or render target. E.g. a factor of 0.8 means that the average dirty area accumulated since the last Renderer::Statistics::Reset is 80% of the size of the screen or render target. The bigger the factor, the less performance improvement can be expected. Under some circumstances, which depends on the actual content being used, performance can even decrease. Therefore always profile this feature to see if your content benefits from it or not.
New Renderer::Statistics properties
Renderer::Statistics now also exposes the number of color buffer, depth buffer, and stencil buffer clears, as well as the number of nodes that were culled due to using a dirty area, and the ratio of the average dirty area to its screen/render target area.
CanvasGroup::TranslatePivot renamed
CanvasGroup::TranslatePivot has been renamed to CanvasGroup::TranslatePivot2D.
PlanarShadow::GetId and SetId renamed
PlanarShadow::GetId has been renamed to PlanarShadow::GetStencilBufferId. In the same manner also PlanarShadow::SetStencilBufferId.
Camera Look-At Node
A new feature allows to set a look-at node for a camera. If such a node is set the camera will always look at that node.
- See also:
- Camera::SetLookAtNode.
Normalize Rectangle from Render Target Space
A new function to normalize a given rectangle from the render target space has been added.
- See also:
- Math3D::NormalizeRectangle().
