Migration Guide
Following an overview about interface changes between Candera V3.2.0 and Candera V3.2.1.
Description Candera V3.2.0
Candera V3.2.1
Activating ClearMode moved to Renderer ClearMode::Activate()
Renderer::ActivateClearMode(const ClearMode*)
Activating ClearMode via Camera moved to Renderer ClearMode::Activate(const Camera&)
Renderer::ActivateClearMode(const Camera&)
Setting a shader uniform moved to Renderer RenderDevice::SetUniform(Handle, const Char*, const void*, Shader::UniformType, UInt)
Renderer::SetUniform(Handle, const Char*, const void*, Shader::UniformType, UInt)
Submitting a drawcall moved to Renderer RenderDevice::DrawVertexBufffer(const VertexBuffer&)
Renderer::Draw(const VertexBuffer&)
Submitting an instanced drawcall moved to Renderer RenderDevice::DrawInstancedVertexBuffer(const VertexBuffer&, UInt32)
Renderer::Draw(const VertexBuffer&, UInt)
Setting the transformation matrix moved to Renderer2D RenderDevice2D::SetTransformationMatrix(ContextHandle2D, SurfaceType, const Matrix3x2&)
Renderer2D::SetTransformationMatrix(ContextHandle2D, SurfaceType, const Matrix3x2&)
Blit moved to Renderer2D RenderDevice2D::Blit(ContextHandle2D)
Renderer2D::Blit(ContextHandle2D)
Clear moved to Renderer2D RenderDevice2D::Clear(ContextHandle2D, Float, Float, Float, Float)
Renderer2D::Clear(ContextHandle2D, Float, Float, Float, Float)
Implementation of GlyphCacheAccess::Create UInt8* CustomGlyphCache::Create(const GlyphBitmap &bitmap) { Create and return new item based on bitmap }
UInt8* CustomGlyphCache::Create(const GlyphBitmap &bitmap, UInt8* cacheItem) { Create or update the cacheItem and return it. }
