FeatStd CMake Switches
V3.2.0 V3.2.1
FEATSTD_MONITOR_TYPE MONITOR_COM_TYPE
FEATSTD_MONITOR_BLOCK_UNTIL_CONNECT MONITOR_BLOCK_UNTIL_CONNECT
FEATSTD_MONITOR_TCPIP_PORT MONITOR_TCPIP_PORT
FEATSTD_MONITOR_TCPIP_ADDRESS MONITOR_TCPIP_ADDRESS
FEATSTD_MONITOR_TCPIP_STACK_ENABLED MONITOR_TCPIP_STACK_ENABLED
FEATSTD_MONITOR_SERIALPORT_BAUDRATE MONITOR_SERIALPORT_BAUDRATE
FEATSTD_MONITOR_SERIALPORT_ADDRESS MONITOR_SERIALPORT_ADDRESS
PERFORMANCE_RECORDER_GENERATION_DIR MONITOR_CANDERA_PERFORMANCE_RECORDER_GENERATION_DIR
PERFORMANCE_RECORDER_TEMPLATE_DIR MONITOR_CANDERA_PERFORMANCE_RECORDER_TEMPLATE_DIR
Existing monitor settings have been moved from code to CMake settings:
These flags are marked as advanced and should only be changed if the current settings have side effects.
Name Description Possible values
MONITOR_CANDERA_PERF_RECORD_BUFFER_SIZE Defines the buffer size on target which is used for performance log tracing.
When only perf-log streaming is used, it can use a smaller buffer.
4000 as size can be enough then. The effective minimum requirement depends on the amount of recorders.
positive integer
MONITOR_CANDERA_PERF_RECORD_STRID_BUFFER_SIZE Defines the maximum of stored strings that can be sent (performance logs)
with an id to reduce payload.
positive integer
MONITOR_CANDERA_PERF_RECORD_STRING_SIZE Defines the maximum length of a single string that can be sent (performance logs). positive integer
