This solution represents an advanced 2D cluster example. It consists of various scenes that are necessary to represent an advanced Cluster. The Main Scene consists of gauges that can be manipulated with Controls and Behaviors. This documentation includes a tutorial of how this advanced gauges can be implemented without coding. Other scenes, like the coverflow, show some other interactions in the solution and how this can be achieved with Behaviors. Culture is also used to support switching between display languages. Furthermore, a scene with a dynamic list is included in the sample. The dynamic list is the result of the tutorial that can be found under Dynamic List
Purpose
The solution shows how simple it is to implement an advanced looking cluster without coding. The cluster includes interactive elements like a cover-flow and a dynamic list.
| (1) | Scene2D_Main | The main scene of this sample solution. Two gauges are displayed on the left and right, various indicators are displayed at the top, and infotainment is displayed in the center. |
| (2) |
Scene2D_Music /Scene2D_Phone /Scene2D_Settings |
A scene that displays infotainment (Music/Phone/Settings). Only the selected scene is displayed in the center of Scene2D_Main. |
| (3) | Scene2D_ControlPanel | A UI for operating the main scene and infotainment scene is displayed. Using the UI, you can change the speedometer/tachometer values, switch infotainment scenes, change the display language, and more. |
Advanced Cluster Part 1 to Part 4 are step-by-step tutorial of customizing a gauge by using the built in controls as a base. More design elements and behaviors are used to change its look and extend its logic. The gauges represent the main scene of this sample solution.
