View Definition Editor
View Definition Editor lets you define “screen-level Views” by combining Scenes created in SceneComposer with existing Views, and make those definitions available to the View Tree, the State Machine, and the Action Chain Editor.
On the View Definition Editor panel, onlyOnly Views are placeddisplayed as nodes in the tree.tree Ifof the View Definition Editor panel. Therefore, if you dragwant andto dropuse a Scene, ontoyou themust panel,always ainclude new View that contains that Scene is created automatically and addedit as a childcomponent node.of Thisone way,of the Views. For details, see View composition later in this document. With this structure, the state machine can alwaysconsistently operate in terms oftreat “which screen (View) to activate,”activate” at the View level, while still incorporating Scene-based content can still be incorporated into the overall screen composition.
View Definition Editor UI
Panel layout
Double-click any View in Solution Explorer to open the View Definition Editor panel.
By default, the View Definition Editor panel is hidden. To display it, choose View > View Editor > View Definition Editor from the menu bar.
UI item Description
View Composition pane (orange frame in the figure above)
Lists which Scenes/Views the selected View is composed of. Add or remove Scenes and existing Views by drag and drop.
Preview area (red frame in the figure above)
Displays preview images of the Scenes/Views associated with the View.View in the right pane, where you can also adjust their layout positions. Useful for improving visual identification when referencing this View from the stateState machineMachine or View Tree.
Basic operations
This section outlines common procedures for defining and editing Views with the View Definition Editor.
For instructions on creating a View, see the View feature overview page.
View composition
OnIn the View Definition Editor panel, you can use the editor’stree treestructure to edit or delete child Views.Views under the currently opened View. You can also inspectreview the hierarchyentire tree rooted at that View on the tree, including the hierarchical relationships of its child Views and their descendant Views.
The composition editing described here applies to Views that were created as new Views. Views that were automatically generated from a Scene are treated as simple Views that display the corresponding Scene, and you cannot edit the tree structure in the View Definition Editor or attach child Views or additional Scenes under them.
    Double-click the View in Solution Explorer whose composition you want to edit.
      The View Definition Editor panel opens and displays the composition of the selected View—including its descendants—directly on the tree.
        In Solution Explorer, double-click the View you want to work on.
          The View Definition Editor panel opens and shows the selected View’s composition.
          View.
          In the View Composition pane, edit the elements included in the View.
          • If
            Addthe elementstarget View does not yet have a Scene as a child element, you can add a Scene or an existing View by dragdragging and dropdropping it from Solution ExplorerExplorer.
          (If the target View already has a Scene as a child element, you cannot add any additional Scenes or existingViews Views)(a View that contains a Scene as a child is always treated as a leaf node).
          To remove anunnecessary elementelements (Scene/View)Scenes/Views), select itthem and choose Delete from the context menu.
          Behavior when dragging and dropping a Scene
          On the View Definition Editor panel, onlyOnly Views are placedshown as nodes in the tree. Insteadtree of attachingthe View Definition Editor panel. If you want to work with a Scene, you add it as internal content of an existing View.
            When you drag and drop a Scene directlyfrom underSolution Explorer into the tree,Composition pane of the editorView automaticallycurrently createsopen in the View Definition Editor, the Create View dialog appears if there is no existing View that already has that Scene as its child. If you accept the creation in the dialog, a new View that contains the Scene as its child is automatically generated and addsadded thatto Viewthe tree as a child View of the drop target View.
            With this mechanism, the View Definition Editor tree can consistently treat the unit of screen transitions and visibility control as Views.
              while Whenstill allowing you dragto andbuild dropScene-based acontent Scenewithin ontothose aViews.
              Grandchild View
              on
              In the View Definition Editor panel, a dialogsingle asksoperation whethercan add Views only up to the child View directly under the currently open View (one hierarchy level down). To create a newstructure with three or more hierarchy levels, such as Parent View > Child View > Grandchild View, you must use only Views that meet the following requirements as the starting point:
                The View you want to use as the parent level must be a newly created View.
                The View you want to holduse as the parent level must not already have a Scene as its child element.
                Views that Scene.were Ifautomatically yougenerated confirm,from a Scene, or Views that already have a Scene as a child, cannot be used as the starting point for building a grandchild hierarchy (these Views are always treated as leaf nodes).
                Using a View that encapsulatesmeets these requirements as the Scenestarting ispoint, generated automatically and added to the tree as that View’s child.
                This mechanism lets the tree always treat the unit of screen transition and visibility control ascreate a three-level structure (Parent View, while> stillChild composingView Scene-based> content inside it.
                Grandchild View
                On the View Definition Editor panel, you can compose at most one hierarchy level under a View (parent > child). You cannot add a grandchild View directly. To build a structure with two hierarchy levels (parent > child > grandchild), proceed) as follows:
                1. Open the View you want to use as the parent Viewlevel, and add a child View under it (firstParent hierarchyView level)> Child View).
                2. Open that
                  Double-click the View you added as the child View in step 1 to open it, and then add another View under it as its child (childChild View > Grandchild View).
                  (second hierarchy level—the grandchild).
                After performing these steps, reopeningreopen the original parent ViewView. willYou showcan then confirm in the tree that a three-level hierarchy as(Parent parentView > childChild View > grandchildGrandchild View.) is displayed.
