View
View sits above Scene in the hierarchy: you can treat a single Scene as one screen, or group multiple Scenes and/or existing Views into a single screen state. Each View is a logical unit that specifies what content to display and how to display it on a given screen. On the engine side, Views are identified by the dedicated identifier type ViewIdentifier.
A View is authored primarily in the View Definition Editor, and the result is referenced as a common screen-level object from the View Tree, the State Machine, and the Action Chain Editor. Screen showing and hiding is handled automatically as part of internal processing, so users do not need to configure display-control elements directly. In the View Tree, you define the transition structure between multiple Views as a tree, and this information is exported as a Global State Machine asset. Furthermore, by combining the Action Chain Editor and the Condition Editor, you can design view-level screen transitions and event logic that respond to input devices and the solution state.
By introducing Views, you can keep Scene-level layout definitions separate from screen-level transition/control logic, while organizing and maintaining the solution’s overall screen composition consistently at the View level.
Create a View (from a Scene)
When you create a View starting from a Scene, that Scene is automatically associated with the newly created View. You can use it immediately as the View that displays that Scene.
  1. In Solution Explorer, select any Scene, then choose Create View… from the context menu.
    • The Add New View dialog opens.
  2. Configure the required settings and click OK.
    • The value set in Name is used as the View’s display name in Solution Explorer.
    • The same value is also assigned automatically as the View Identifier.
  3. A new View is created in Solution Explorer with the selected Scene as its child.
This operation automatically establishes the association between the View and the Scene.
Create a View (New Item)
If you create an empty View, you must later add and associate Scenes in the View Definition Editor. This method lets you flexibly build composite Views that combine multiple Scenes.
  1. In Solution Explorer, open the context menu at the desired location and choose Add > New Item.
  2. From the left menu, select View.
    • The View settings appear on the right.
  3. Configure the required settings and click OK.
  4. A new View is created in Solution Explorer.
Because a View created by this method has no Scene associated yet, you need to add the Scene(s) you want to display later in the View Definition Editor.
