Building Own Application for Linux with a Wayland Display Server
Generate Makefiles with CMake
- Folder containing top-level "CMakeLists.txt", e.g. \cmake\Candera\Player
- Configure
- Specify “Unix Makefiles” as generator for the project
- /cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Linux.txt
OpenGL ES 2.0 and 3.0 versions are supported please configure CMake variable "CGIDEVICE_GLES_VERSION"
- Adapt the CMake settings if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release
- Press Configure.
- Press Generate.
Building Application
use same Terminal session for all steps.
- Initialize the cross-compile environment variables first have to be set with following command
. /<path-to-yocto-installation>/environment-setup-... - Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
- After generating your cmake files, simply navigate to the specified build directory (binary directory created in CMake GUI) and type "make" within terminal to start the build process.
For CourierSampleApp and CitDemoApp asset file have to be created with their own SCHost.dll
