Building Own Application for QnxScreen
Generate Makefiles with CMake
Open
a
    terminal. Set the environment. This step is mandatory. Omitting this step will cause building with the host systems compiler instead of cross compiling.
    call C:\Users\<username>\qnx<version>\<version>\qnxsdp-env.bat
    From this console open CMake.
    Point CMake to source directory
    • Folder containing top-level "CMakeLists.txt", e.g.
       /cmake/Candera/Player
    Point CMake to buildbinary directory
      Configure
      • Specify Ninja Makefiles as generator for the project
      Select the toolchain-file from the delivery (adapt for your toolchain installation and application specific needs)
      •  /cgi_studio_devices/src/QnxScreen/ToolchainFiles/GCC-toolchain-<board>-QnxScreen-QNX.txt
      Adapt the CMake settings if necessary, e.g.:
      • Press Configure
      Press Generate
      Building Application
      Use same Command Prompt window for all steps.
      1. QNX environment variables first have to be set with qnxsdp-env.bat (QNX70\).
      2. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake
      3. After generating your cmake files, simply navigate to the specified build directory (binary directory created in CMake GUI) and type "ninja" to start the build.
