Building Own Application for QnxScreen
Generate Makefiles with CMake
    • Folder containing top-level "CMakeLists.txt", e.g.
       /cmake/Candera/Player
  2. Point CMake to build directory
  3. Configure
    • Specify Ninja Makefiles as generator for the project
    •  /cgi_studio_devices/src/iMX8_2Dover3D/QnxScreen/ToolchainFiles/GCC-toolchain-iMX8_2Dover3D-<board>-QnxScreen-QNX.txt
    • Press Configure
  6. Press Generate
Building Application
Use same Command Prompt window for all steps.
  1. QNX environment variables first have to be set with qnxsdp-env.bat (QNX70\).
  2. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake
  3. After generating your cmake files, simply navigate to the specified build directory (binary directory created in CMake GUI) and type "ninja" to start the build.
