Building Own Application for QnxScreen
Generate Makefiles with CMake
- Folder containing top-level "CMakeLists.txt", e.g.
/cmake/Candera/Player
- Point CMake to build directory
- Configure
- Specify Ninja Makefiles as generator for the project
/cgi_studio_devices/src/QnxScreen/ToolchainFiles/GCC-toolchain-<board>-QnxScreen-QNX.txt
- Adapt the CMake settings if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release
- Press Configure
Press Generate
Building Application
Use same Command Prompt window for all steps.
- QNX environment variables first have to be set with qnxsdp-env.bat (QNX70\).
- Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake
- After generating your cmake files, simply navigate to the specified build directory (binary directory created in CMake GUI) and type "ninja" to start the build.
