CGI-Player Launcher
System Requirements
This document mandates adherence to the Android Application Development Environment
Setup Guide,Guide, as a prerequisite for system compliance.
ByThe followingproject theserequirements steps,
you
shouldCGI-Player have a consistent and well-configured development environment for yourLauncher Android application on Windows 10/11. Remember to restart your system after making changes related to CMake in Android Studio and after updating Environment Variables.
Project Structure
CGI-Player Launcher is usinguses the Android Gradle Plugin Versionversion 7.2.1 and Gradle version 7.3.3.
A custom NDK 26 is required, as described in the Android Native Development Kit (NDK) chapter.  CMake 3.5.322.1 is required as described in the CMake chapter. Eclipse Temurin JDK 11 is required as described in Java Development Kit (JDK) chapter. Supported API levels: 23–28 (The application is compatible with Gradlelater VersionAndroid 5.4.1.versions The
Applicationup is tested with ndk-26 that can be installed from the document in chapter Configuration and System Requirements. The supportedto API range36 ison 23-28.Android The16). supportedSupported ABIsABIs: are arm64-v8a, x86_64, x86.x86 The CGI-Player Launcher Android Applicationapplication is usingintegrates the NativeView librarylibrary, includedwhich inis provided externally from ../libs/nativeview-lib and already imported into the Androidproject. Application. This NativeView Library is moved out of the project directory and will be included from outside of the project as library.
To be able to build and run the Android Application,application, perform the following steps must be done.
steps:
    1.
    SubstSubstitute [the CGI Studio root as described in the windows-commands/subst] thearticle. root of CGI Studio.
      Open a Command Prompt in the root of CGI Studio root directory (e.g., “...\cgistudio”) and type: “
      subst
       x: .” and
      click
      Press enter.enter. The CGI root is now available under the subst "x"X: drive in Windows Explorer.
      2.
      Open the Android ApplicationApplication: in
      Launch Android Studio fromand “open the project located at:
      X:\cgi_studio_apps\References\Android\AndroidCgiPlayerLauncher”.
        • Open the “local.properties.sample”sample file and changefrom the “USERNAME”root of the Android application.
        Copy the content of the sample to the local.properties file in the root of the Android application. Update the USERNAME in the SDK and NDK pathpaths to match the
        systemyour itsystem. will be used on. Also the path toHow the asset and ABI can be setloaded here.is Thisdescribed in the Asset Configuration block. Set the ABI should matchto the target CPU architecture.
        architecture
        under
        the Target ABI block. CopySave thelocal.properties contentsand ofsync theproject "local.properties.sample"with toGradle “local.properties”files (Ctrl+Shift+O). Note that if
        Note: If the SDK or NDK paths do not exist, Android Studio willmay reset the “local.properties” againproperties after tryingsyncing tothe Sync Projectproject with Gradle Files.files.
        Make
        4. sureCreate an Android asset
        Run the JDKfollowing isbatch setfile:
        to
        11
        in [File | Settings | Build, Execution, Deployment | Build Tools | Gradle] like described in chapter Java Development Kit (JDK).
        • Create
          •  Choose an asset withtemplate CGI Studio for Android by running “X:\bin\SceneComposer\SceneComposer_Android_OpenGLES30.bat” and choosing (e.g., “3D Basic”) and save this as Test.bin into
            • If from sdcard: to the /sdcard/ directory of the target/target or emulator. ForIn theAndroid emulatorStudio, this can be done in the "Device Explorer" of the target or emulator.
            If from APK: to the following folder:
            5. Build variant:
                In Android Studio, open [View | Tool Window | Build Variants]. In the Build Variants tool window, select debug or release under Active Build Variant.
                6. Run the application:
                    Select the target device or emulator in Android Studio. Click Run (the Applicationplay by selecting the target/emulator and clicking on “run sample”.button) The first time the Application starts, it will request permissions. ClickAccept accept.and restart the application. AfterThe choosingassets are loaded from the location that is set in the Asset Location option in the application. The desired asset incan be clicked on and the list, the solutionasset should be running.
                    The asset path can be found in the CGI-Player Launcher app. Replace the asset path and asset filename in the command. Use this method to start the CGI-Player Launcher and open a selected asset from cmd:
                    7. APK
                    After the application is running, the current built APK can be found in the build directory. This can located by opening [Build | Analyze APK]. The usual directory would be:
                    Troubleshooting
                    • If
                    you encounter any issues linked to outdated source code, reach out to the Android developers for
                    assistance in implementing a resolution. Check for updates regularly and keep your development environment components up to date.
                    Platform Tests
                    • Google Pixel C, ARM Cortex A57, Android 8.1.0, API 27
                    • Huawei MediaPad M5, ARM Cortex A73, Android 9, EMUI 9.1.0, API28
                    • Emulator Pixel 2, x86_64, Android 6, API 23 (Without Play/APIs)
                    • Emulator Medium Phone, x86_64, Android 9, API 28 (Without Play/APIs)
                    • Emulator Pixel 2, x86, Android 9, API 28 (Without Play/APIs)
                    • Emulator Google Pixel Tablet, x86_64, Android 14.0, API 34
                    Emulator Google Pixel Tablet, x86_64, Android 16.0, API 36 Emulator Google Pixel 9 Pro XL, x86_64, Android 16.0, API 36
