Player Configuration
Panel Path
Press the [ Browse ] button and specifySpecifies the path to the CGI Panel. Normally,By youdefault, dothe notpath needpoints to changethe it.correct executable but the path can be changed or browsed for with the [ Browse ] button.
Panel Path Type
Specify the path type to the CGI panel from the following three types. [ Relative to Scene Composer] is selected by default.
  • Absolute
  • Relative to solution
  • Relative to Scene Composer
System Parameters Parameters that are automatically sent to the player at startup (not editable).
User Perameters
When customizing theAdditional command line, set anyline arguments can be customized here. InThese arguments will be executed in addition to the commandarguments specified onin theSystem command line, the arguments entered here will be executed.Parameters.
Default Scene
Select the scene that will be selected by default for the player. To use this option,option check the checkbox and select the default scene from the scenes set in the solution.
Application port
Specifies the port to use when setting up a TCP connection with the application. Normally, there is no need to change the default value of "13060".
