Player Configuration
Press the [ Browse ] button and specify the path to the CGI Panel. Normally, you do not need to change it.
Panel Path TypeSpecify the path type to the CGI panel from the following three types. [ Relative to Scene Composer] is selected by default.
When customizing the command line, set any arguments here. In addition to the command specified on the command line, the arguments entered here will be executed.
Default SceneSelect the scene that will be selected by default for the player. To use this option, check the checkbox and select the default scene from the scenes set in the solution.
Application portSpecifies the port to use when setting up a TCP connection with the application. Normally, there is no need to change the default value of "13060".
