Player Configuration
Panel Path
Press the [ Browse ] button and specify the path to the CGI Panel. Normally, you do not need to change it.
Panel Path Type
Specify the path type to the CGI panel from the following three types. [ Relative to Scene Composer] is selected by default.
  • Absolute
  • Relative to solution
  • Relative to Scene Composer
System Parameters Parameters that are automatically sent to the player at startup (not editable).
User Perameters
When customizing the command line, set any arguments here. In addition to the command specified on the command line, the arguments entered here will be executed.
Default Scene
Select the scene that will be selected by default for the player. To use this option, check the checkbox and select the default scene from the scenes set in the solution.
Application port
Specifies the port to use when setting up a TCP connection with the application. Normally, there is no need to change the default value of "13060".
