Default Shader Params
For Shader Configuration in detail, see Shader Configuration.
On this panel, you can change the default names of values specific to the semantics of the UniformSetter.
    Select the target for editing from the [ Auto Uniform ] and [ Shader Attributes ] tabs.
    After changing the default name, click the arrow button (the orange frame in the above image) to return the name to the default name.
    Clicking on [ Reset All ] will return all edited items to their default names.
    Clicking [ Clear All ] will delete all names.
    When the editing operation is complete, click [ OK ] button at the bottom of the Solution Options dialog to save the edited results.
    If [ Cancel ] button is pressed, the edits will not be saved.
