Shader Configuration
The Solution option allows for Default Shader Configurations.
Add a New Vertex or Fragment Shader
- Vertex Shaders
- Fragment (or Pixel) Shaders
For information about how to import a Vertex or Fragment shader please refer to section How to Import Resources.
Add a New Shader Program
Create a new shader program:
Shader Editor
Shader Editor Features
For further information please refer to section Compile Shaders.
Compile Shaders
- During shader editing, if requested via menu item "Shader" > "Compile Shader" or by pressing F7 key, the selected shader or shader program will be compiled using the platform's shader compiler.
- During scene editing, when the scene dependencies are generated, the shaders will be compiled using an internal shader compiler (so called "builtin://DefaultShaderCompiler").
- During asset generation, depending on the selected shader compiler type, the shaders will be compiled using platform's shader compiler (Target) or internal shader compiler (Simulation).
Shader Parameters
SceneComposer offers the necessary support to define shader parameters for uniform and attribute values. For every shader, Candera supplies a list of uniforms and their corresponding types. Uniforms are set via UniformSetters.
Instanceable Shaders
- "u_PMatrix", // ProjectionMatrix4
- "u_VPMatrix", // ViewProjectionMatrix4
- "u_CamPosition", // CameraPosition
- "u_CamDirection", // CameraLookAtVector
- "u_Texture", // Texture
- "u_Texture1", // Texture1
- "u_Texture2", // Texture2
- "u_Texture3", // Texture3
- "u_Texture4", // Texture4
- "u_Texture5", // Texture5
- "u_Texture6", // Texture6
- "u_Texture7", // Texture7
- "u_CubeMapTexture", // CubeMapTexture
- "u_CubeMapTexture1", // CubeMapTexture1
- "u_CubeMapTexture2", // CubeMapTexture2
- "u_CubeMapTexture3", // CubeMapTexture3
- "u_CubeMapTexture4", // CubeMapTexture4
- "u_CubeMapTexture5", // CubeMapTexture5
- "u_CubeMapTexture6", // CubeMapTexture6
- "u_CubeMapTexture7", // CubeMapTexture7
- "u_Light[0].type", // LightType
- "u_Light[1].type", // LightType1
- "u_Light[2].type", // LightType2
- "u_Light[3].type", // LightType3
- "u_Light[4].type", // LightType4
- "u_Light[5].type", // LightType5
- "u_Light[6].type", // LightType6
- "u_Light[7].type", // LightType7
- "u_Light[0].ambient", // LightAmbient
- "u_Light[1].ambient", // LightAmbient1
- "u_Light[2].ambient", // LightAmbient2
- "u_Light[3].ambient", // LightAmbient3
- "u_Light[4].ambient", // LightAmbient4
- "u_Light[5].ambient", // LightAmbient5
- "u_Light[6].ambient", // LightAmbient6
- "u_Light[7].ambient", // LightAmbient7
- "u_Light[0].diffuse", // LightDiffuse
- "u_Light[1].diffuse", // LightDiffuse1
- "u_Light[2].diffuse", // LightDiffuse2
- "u_Light[3].diffuse", // LightDiffuse3
- "u_Light[4].diffuse", // LightDiffuse4
- "u_Light[5].diffuse", // LightDiffuse5
- "u_Light[6].diffuse", // LightDiffuse6
- "u_Light[7].diffuse", // LightDiffuse7
- "u_Light[0].specular", // LightSpecular
- "u_Light[1].specular", // LightSpecular1
- "u_Light[2].specular", // LightSpecular2
- "u_Light[3].specular", // LightSpecular3
- "u_Light[4].specular", // LightSpecular4
- "u_Light[5].specular", // LightSpecular5
- "u_Light[6].specular", // LightSpecular6
- "u_Light[7].specular", // LightSpecular7
- "u_Light[0].position", // LightPosition
- "u_Light[1].position", // LightPosition1
- "u_Light[2].position", // LightPosition2
- "u_Light[3].position", // LightPosition3
- "u_Light[4].position", // LightPosition4
- "u_Light[5].position", // LightPosition5
- "u_Light[6].position", // LightPosition6
- "u_Light[7].position", // LightPosition7
- "u_Light[0].direction", // LightDirection
- "u_Light[1].direction", // LightDirection1
- "u_Light[2].direction", // LightDirection2
- "u_Light[3].direction", // LightDirection3
- "u_Light[4].direction", // LightDirection4
- "u_Light[5].direction", // LightDirection5
- "u_Light[6].direction", // LightDirection6
- "u_Light[7].direction", // LightDirection7
- "u_Light[0].halfplane", // LightHalfplane
- "u_Light[1].halfplane", // LightHalfplane1
- "u_Light[2].halfplane", // LightHalfplane2
- "u_Light[3].halfplane", // LightHalfplane3
- "u_Light[4].halfplane", // LightHalfplane4
- "u_Light[5].halfplane", // LightHalfplane5
- "u_Light[6].halfplane", // LightHalfplane6
- "u_Light[7].halfplane", // LightHalfplane7
- "u_Light[0].attenuation", // LightAttenuation
- "u_Light[1].attenuation", // LightAttenuation1
- "u_Light[2].attenuation", // LightAttenuation2
- "u_Light[3].attenuation", // LightAttenuation3
- "u_Light[4].attenuation", // LightAttenuation4
- "u_Light[5].attenuation", // LightAttenuation5
- "u_Light[6].attenuation", // LightAttenuation6
- "u_Light[7].attenuation", // LightAttenuation7
- "u_Light[0].spotCosCutoff", // LightSpotCosCutoff
- "u_Light[1].spotCosCutoff", // LightSpotCosCutoff1
- "u_Light[2].spotCosCutoff", // LightSpotCosCutoff2
- "u_Light[3].spotCosCutoff", // LightSpotCosCutoff3
- "u_Light[4].spotCosCutoff", // LightSpotCosCutoff4
- "u_Light[5].spotCosCutoff", // LightSpotCosCutoff5
- "u_Light[6].spotCosCutoff", // LightSpotCosCutoff6
- "u_Light[7].spotCosCutoff", // LightSpotCosCutoff7
- "u_Light[0].spotExponent", // LightSpotExponent
- "u_Light[1].spotExponent", // LightSpotExponent1
- "u_Light[2].spotExponent", // LightSpotExponent2
- "u_Light[3].spotExponent", // LightSpotExponent3
- "u_Light[4].spotExponent", // LightSpotExponent4
- "u_Light[5].spotExponent", // LightSpotExponent5
- "u_Light[6].spotExponent", // LightSpotExponent6
- "u_Light[7].spotExponent", // LightSpotExponent7
- "u_Light[0].range", // LightRange
- "u_Light[1].range", // LightRange1
- "u_Light[2].range", // LightRange2
- "u_Light[3].range", // LightRange3
- "u_Light[4].range", // LightRange4
- "u_Light[5].range", // LightRange5
- "u_Light[6].range", // LightRange6
- "u_Light[7].range", // LightRange7
- "u_Light[0].enabled", // LightEnabled
- "u_Light[1].enabled", // LightEnabled1
- "u_Light[2].enabled", // LightEnabled2
- "u_Light[3].enabled", // LightEnabled3
- "u_Light[4].enabled", // LightEnabled4
- "u_Light[5].enabled", // LightEnabled5
- "u_Light[6].enabled", // LightEnabled6
- "u_Light[7].enabled", // LightEnabled7
- "u_Light[0].cameraLookAtVector",// LightCameraLookAtVector
- "u_Light[1].cameraLookAtVector",// LightCameraLookAtVector1
- "u_Light[2].cameraLookAtVector",// LightCameraLookAtVector2
- "u_Light[3].cameraLookAtVector",// LightCameraLookAtVector3
- "u_Light[4].cameraLookAtVector",// LightCameraLookAtVector4
- "u_Light[5].cameraLookAtVector",// LightCameraLookAtVector5
- "u_Light[6].cameraLookAtVector",// LightCameraLookAtVector6
- "u_Light[7].cameraLookAtVector",// LightCameraLookAtVector7
Shader Consistency Checker
| Warning | Diagnostic | Possible resolutions |
| SemanticNotMappedToUniform, SemanticNotMappedToAttribute | This problem is reported when a uniform or attribute semantic is not mapped to any parameter name in the shader. |
| ShaderAttributeNotMappedToSemantic | This problem is reported when the shader contains an attribute which is not mapped to a semantic. |
| VBAttributeMissing | This problem is reported when an attribute defined in the shader has no matching data in the vertex buffer. |
| VBAttributeTypeInvalid | This problem is reported when the type of the vertex data or the type of the attribute defined in the shader is invalid or there was an error retrieving them. |
| VBAttributeTypeExtraChannels | This problem is reported when the vertex data contains too many channels compared to the attribute defined in the shader. For example an attribute is defined in the shader as a vector of 2 floats and the vertex data has a vector of 3 floats. |
| VBAttributeTypePotentialPrecisionLoss | This problem is reported when there is a (potential) precision loss while loading the attribute data contained in the vertex buffer into the attributed defined in the shader. For example vertex data type is Float32 and the shade attribute type is Medium Float. |
| VBAttributeTypePrecisionWaste | This problem is reported when there is a "precision waste" while loading the attribute data contained in the vertex buffer into the attribute defined in the shader. For example vertex data type is Int8 and the shader attribute type is High Int. |
| VBAttributeTypeConversionToInt, VBAttributeTypeConversionToFloat | This problem is reported when there is a type conversion while loading the attribute data contained in the vertex buffer into the attribute defined in the shader. For example vertex data type is float and the shader attribute type is int. |
| SemanticNotSupportedByUniformSetterButUsedByShaderProgram | This problem is reported when the semantic of a uniform defined in the shader is not supported by the uniform setter. Currently all semantic are supported. | |
| SemanticNotEnabledInUniformSetterButUsedByShaderProgram | This problem is reported when the semantic of a uniform defined in the shader is not enabled in the uniform setter. |
| SemanticEnabledInUniformSetterButNotUsedByShaderProgram | This problem is reported when the semantic of a uniform not defined in the shader is enabled in the uniform setter. |
Generic ShaderParamSetter
A relationship between the semantics of the UniformSetter and all the properties of the shader should be established. The semantics of the UniformSetter contain specific values that could be activated/deactivated in direct relationship with the shader. In In [ Solution Option >Default Shader Params ] from the menu bar allows to change the default names of all these values specific for the semantics of the UniformSetter.
Clone, Rename, Delete a Shader
- "Clone" will make a copy of the shader program. The name of the copy will be the name of the item suffixed with a number.
- "Delete" will cause a "Delete solution item" dialog to appear. If the item is not used somewhere in the solution, it can be deleted by clicking "OK". If the item is used, the "Delete Solution Item" dialog will list the paths of the items where it is used, and the "OK" is disabled, making the deletion not possible.
- "Rename" will cause a "Rename Solution Item" dialog to appear. The new desired name can be typed in the text box.
