Pollen Infoscreen
Run Pollen Infoscreen Sample
To run the solution with the player connector in IMPORTANTsimulation environment: Pleasethe following steps have to be executed:
    Generate the simulation asset of the Pollen Infoscreen Sample Solution and save it in
    <cgi-studio-installation-path>\bin\CommunityEdition\Python\Samples\PollenInfoScreen Obtain the API Key from Polleninformation Datenschnittstelle / API | Polleninformation.
    Use the contact form to request aan newAPI Key.
    Your API key tocan usebe set in line 276 of the associatedscript
    <cgi-studio-installation-path>\bin\CommunityEdition\Python\Samples\PollenInfoScreen\PollenInfoScreen.py, scriptas (seeseen collapsible block below).below.
    more info onExecute the deploymentpython onscript
    Example HWusage: please check
    python ourPollenInfoScreen.py Target^
    Setup-lbp Guide..\..\..\RaspberryPi_Simulation\PlayerConnector\PlayerConnectorLibrary.dll ^
    -abp PollenInfoScreen.bin
    Parameters:
      -lbp (Library Binary Path)
      Path to the PlayerConnector library
      <cgi-studio-installation-path>\bin\CommunityEdition\RaspberryPi_Simulation\PlayerConnector\PlayerConnectorLibrary.dll
      -abp: (Asset Binary Path)
      Path to the asset saved previously
      To run it on the Target please follow the steps from Run Sample with Player Connector Library.
      Overview scene:
      Dynamic Elements:
      • Clock control
      • Air Quality – text value
      • DayRisk control (4 week days)
      • Pollen_Brief control (level of preselected contaminant, with 4 levels, triggers list of contaminants)
      • City Button (triggers location list)
      • Insights Button (switches to contaminants list scene)
      Insights scene
      ContaminantListElement control – List element, composed of other controls:
      • ContaminantName control
      • 4 x ContaminantLevel
      Controls
      DayRisk
      The risk value has a single entry point and is forwarded to the three controls that each need it. This could also have been done with using fewer elements and arithmetic operator behavior. This is a bit more flexible as it allows to easily add new images for each value, if needed.
      PollenBrief
      MultihourValue
      ContaminantLevel
      ContaminantName
      ContaminantsListElement
      Contaminant
      The Radio button has a “Value” behavior, which will become true when selected, and false when deselected. Under this value we have 2 “Action On Value” behaviors, one to trigger actions when becoming selected, and one to trigger actions when becoming unselected.
      Country
      City
      The city button template has to send the city name, the country code, and the longitude and latitude of the city. These could naturally be represented as floating point numbers, but they will be needed as strings when creating a web request anyway, so we can set them to string type. The country code is sent from here and not the country list, to keep them consistent, in case the country is changed and no new city is selected.
      Contaminants_List
      GroupBox_List
      Scenes
      Overview Scene
      This scene is the most complex of the solution, but it can be managed easily by using several of the templates previously described.
      TopLeft: Here we just have a number from 0 to 10, showing the allergy risk for today, and some static text around it. A default “Text Value” control is used, and configured with font style, color, format and data binding.
      TopRight: Here we have a list of allergy risk values for today and the next 3 days. Beside the value and day of the week, each also has an icon and fixed text for none, low, moderate, or high risk. For this we use the DayRisk template, and a StackLayout to allign them automatically.
      Bottom Left: This displays the allergy risk values during the current day, at 4 hour intervals. The web api provides hourly values, and we display 6 of them, using images associated for value, via the MultihourValue template. The elements are also allligned automatically using a StackLayout.
      Bottom Right: Here the user can select a set of 4 contaminants and see the risk level associated with each of them. There are only 4 levels: none, low, mid, high, and no numeric value. We use the PollenBrief template and place them manually. Each element has an associated button, which opens a list from which a user can select a contaminant for the respective slot.
      Insights Scene
      This scene only contains a list of the contaminants we know of and their level. It is only meant to be viewed, there are no buttons for interaction. The elements of the list are ContaminantListItem templates. The list has a fixed number of 8 elements. The number of received contaminants can be higher or smaller. If Higher, we only show the first 8. If lower, we disable rendering for the unused elements via a “Render Child Nodes” behavior. When there are more elements than visible in the given space, a scroll-bar will appear (and scale as well as move itself appropriately). To customize the “Scrollbar” with imported graphical elements, the Contaminants_List template is used.
      TopBar Scene
      BottomBar Scene
      In the bottom bar we have buttons to switch between the 2 main scenes. When the button is clicked, the state machine transition occurs. To select between the gray and green versions, a RenderChildNodes behavior is used.
      ContaminantList_Popup Scene
      Location_popup Scene
      This is the largest scene in the solution. There are 2 lists visible, a countries list and a cities list. In the scene there is a list of cities for each country. The Lists of cities are under a node with a “Render Child Nodes” behavior, so only one of the lists of cities is made visible. The index of the list to show is set from the “Country” template of the first list.  Like the Contaminants List Popup, this scene has a node to prevent events going to the elements under it, and a full screen button to exit when tapping outside.
      Other elements
      Below you can find more information on the remaining elements not beloning in the controls and scenes chapter.
      Associated script (WebAPI)
      The python script can be found in cgi_studio_player/src/PlayerConnector/Python/Samples/PollenInfoScreen, and your API key can be set in line 276 of the script, as seen below.
      State Machine
      Animations
